MCX-J-P-H-RA-SM1
MCX-J-P-H-RA-SM1
    SAMTEC(申泰)
    MCX
MCX-J-P-H-RA-SM1 数据手册
REVISION E MCX-J-P-X-RA-SM1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] 0.45 .018 "A" DO NOT SCALE FROM THIS PRINT GENDER -J: JACK Pb THIS PRODUCT MANUFACTURED WITH LEAD-FREE PROCESSING TERMINATION -SM1: SURFACE MOUNT TYPE -P: PCB ORIENTATION -RA: RIGHT ANGLE 1.50 .059 TO CENTER CONTACT DETAIL 'B' SCALE 16 : 1 PLATING SPECIFICATION -H: HEAVY GOLD 6.76 .266 (REF) 3.77 .148 REF +0.05 "A" 0.76 .030 (REF) 0.92 .036 (REF) +.002 2.75 - 0.15 .108 - .006 TO INSULATOR 0.96 .038 (REF) DETAIL 'C' SCALE 8 : 1 5.08 .200 (REF) 4.50 .177 REF 6.50 .256 REF 2.56 .101 REF TO CENTER CONTACT 3.45 .136 REF SHELL (MCX-SHL-001) 4.06 .160 REF INSULATOR 1 (MCX-INS-006) 9.50 .374 REF DETAIL 'D' SCALE 16 : 1 0.00 - 0.10 .004 TO INSULATOR INSULATOR 2 (MCX-INS-004) RECOMMENDED PCB LAYOUT 1.60 .063 (4 PLCS) SOCKET (MCX-J-P-X-RA-SM1-SKT) 6.00 .236 (REF) 1.60 .063 6.68 .263 .067 [.026] REF BODY (MCX-J-P-X-RA-SM1-BDY) 0.10±0.10 .004±.004 DETAIL 'E' SCALE 16 : 1 SECTION "A"-"A" NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR INSULATOR: 20 N[4.5 LB] MIN. 3. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-HD-WI-3040-M. 4. RoHs COMPLIANT. 5. PLATING: -H: .000030" MIN GOLD OVER .000050" MIN NICKEL -F: .000003" MIN GOLD OVER .000050" MIN NICKEL 6. ASSEMBLY PLATING DESIGNATION: -H: (CENTER CONTACT) -H (OUTER CONTACT) -F (REMAINING METAL PARTS) -F 0.05 .002 TO INSULATOR 6.68 .263 F:\DWG\MISC\MKTG\MCX-J-P-X-RA-SM1-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING CONTACT: BRASS SHELL, BODY: COPPER ALLOY DIELECTRIC: PTFE SHEET SCALE: 5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MCX RIGHT ANGLE, SMT JACK- 50 OHM DWG. NO. MCX-J-P-X-RA-SM1 BY: R MUSSER 02/06/2008 SHEET 1 OF 1
MCX-J-P-H-RA-SM1 价格&库存
很抱歉,暂时无法提供与“MCX-J-P-H-RA-SM1”相匹配的价格&库存,您可以联系我们找货
