MCX7-P-C-H-RA-CA3
MCX7-P-C-H-RA-CA3
    SAMTEC(申泰)
    特性:外壳材料:黄铜。接触材料:铍铜。绝缘材料:聚四氟乙烯(PTFE)。阻抗:ST=75Ω±3Ω,RA = 75Ω±4Ω。频率范围:0~6 GHz。工作电压:最大170 Vrms。耐压:最小500 V...
MCX7-P-C-H-RA-CA3 数据手册
REVISION J MCX7-P-C-XX-RA-CA3 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER -P: PLUG DO NOT SCALE FROM THIS PRINT TERMINATION -CA3: CABLE (RG179) TYPE -C: CABLE ORIENTATION -RA: RIGHT ANGLE PLATING SPECIFICATION -HN:30μ" GOLD CENTER CONTACT, 100μ" NICKEL OUTER CONTACT -H: 30μ" GOLD CENTER CONTACT, 3μ" GOLD OUTER CONTACT (SEE TABLE 1) 1 2 2.70 .106 7.80 .307 REF 3.90 .154 REF 9.50 .374 REF 3 7.00 .276 REF 0.50 .020 REF 2.90 .114 REF 4 0.48 .019 REF 4.43 .174 REF NOTES: 1. NOTE DELETED. 2. NOTE DELETED. 3. NOTE DELETED. 4. NOTE DELETED. 5. PRODUCT TO BE BULK PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. 6. NOTE DELETED. 7. NOTE DELETED. 8. NOTE DELETED. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS PROPRIETARY NOTE * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * THIS DOCUMENT CONTAINS CONFIDENTIAL AND AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL, FERRULE, CAP: BRASS CONTACT: BRASS DIELECTRIC: PTFE SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: TRUE 75 OHM, MCX RIGHT ANGLE PLUG, RG179 DWG. NO. MCX7-P-C-XX-RA-CA3 BY: R MUSSER F:\DWG\MISC\MKTG\MCX7-P-C-XX-RA-CA3-MKT.SLDDRW 02/06/2008 SHEET 1 OF 2 REVISION J RG179 CABLE 1.0 .04 3.1 .12 7.9 .31 IN-PROCESS 1 STRIP CABLE AND TIN INNER CONDUCTOR HEAT SHRINK 2 20.00 .787 IN-PROCESS 2 ADD HEAT SHRINK TUBE AND FERRULE 1 END OF CABLE DIELECTRIC SHOULD SEAT AGAINST CONTACT CUP 'D' DETAIL 'D' CABLE CENTER CONDUCTOR SHOULD NOT PROTRUDE OUTSIDE CONTACT CUP AFTER FERRULE IS CRIMPED 0.25 .010 MAX GAP ALLOWABLE 'B' FERRULE SHOULD BE FLUSH TO SUB ASSEMBLY IN-PROCESS 4 CRIMP FERRULE (USE RF CRIMP HAND TOOL #CAT-RF-FER-01, AND .128" DIE SIZE) DETAIL 'B' IN-PROCESS 5 SOLDER SIGNAL SOCKET 3 4 IN-PROCESS 6 PRESS INSULATOR AND CAP * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, HEAT SHRINK SHOULD BE FLUSH TO SUB ASSEMBLY MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 IN-PROCESS 7 ACTIVATE HEAT SHRINK 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: TRUE 75 OHM, MCX RIGHT ANGLE PLUG, RG179 DWG. NO. MCX7-P-C-XX-RA-CA3 BY: R MUSSER F:\DWG\MISC\MKTG\MCX7-P-C-XX-RA-CA3-MKT.SLDDRW 02/06/2008 SHEET 2 OF 2
