BNC7T-J-P-GN-ST-EM1
BNC7T-J-P-GN-ST-EM1
    SAMTEC(申泰)
    BNC
BNC7T-J-P-GN-ST-EM1 数据手册
REVISION E BNC7T-J-P-XX-ST-EM1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER -J: JACK TYPE -P: PCB DO NOT SCALE FROM THIS PRINT TERMINATION -EM1: EDGE MOUNT (FOR 1.57[.062] THICK PCB) ORIENTATION -ST: STRAIGHT PLATING SPECIFICATION -HN: HEAVY GOLD/NICKEL (SEE NOTES 5 & 6) (SUB-BNC7T-J-P-HN-ST-EM1) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) -GN: GOLD/NICKEL (SEE NOTES 5 & 6) (SUB-BNC7T-J-P-GN-ST-EM1) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) BTNC-NUT-003-X -MN: MEDIUM GOLD/NICKEL (EXISTING CUSTOMERS ONLY) (SUB-BNC7T-J-P-GN-ST-EM1) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) RECOMMENDED MOUNTING HOLE SUB-BNC7T-J-P-XX-ST-EM1 4.00[.157] MAX. PANEL THICKNESS 12.89 .507 11.30 .445 BTNC-LWAS-001-X RECOMMENDED LAYOUT FOR 1.57[.062] PCB 1.35 .053 (2 PLCS) 1.98 .078 PCB TOP 3.10 .122 1.83 .072 FIG 1 BNC7T-J-P-XX-ST-EM1 SHOWN 6.80 .268 (2 PLCS) 4.83 .190 9.65 .380 0.25 .010 (2 PLCS) 0.25 .010 (2 PLCS) 8.50 .335 6.80 .268 (2 PLCS) PCB BOTTOM NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. FABRICATED PARTS MUST BE FREE OF SCRATCHES, TOOL MARKS, ETC. 3. SUPPLIER TO REMOVE BURRS. 4. RoHs COMPLIANT. 5. COMPONENT PLATING DESIGNATIONS: -H: .000030" MIN. GOLD OVER .000050. (MIN) NICKEL. -G .000010" MIN. GOLD OVER .000050" MIN. NICKEL -N: .000100" MIN. NICKEL. 6. ASSEMBLY PLATING DESIGNATIONS: -HN: (CENTER CONTACT)-H (OUTER CONTACT) -N (REMAINING METAL PARTS) -N -GN, MN:(CENTER CONTACT)-G (OUTER CONTACT) -N (REMAINING METAL PARTS) -N 7. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. F:\DWG\MISC\MKTG\BNC7T-J-P-XX-ST-EM1-MKT.SLDDRW 1.50 .059 (2 PLCS) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BNC7T EDGE MOUNT STRAIGHT JACK DWG. NO. BNC7T-J-P-XX-ST-EM1 BY: G.HERMAN 01/04/2008 SHEET 1 OF 2 REVISION E 16.00 .630 REF 1.02 .040 REF 14.30 .563 REF 1/2-28 UNEF 2B THREAD REF 13.00 .512 REF 2.54 .100 REF 2.54 .100 REF 0.50 .020 REF 18.11 .713 REF 12.70 .500 REF 10.92 .430 REF 1.25 .049 REF 9.65 .380 REF 2.48 .098 1/2-28 UNEF 2A THREAD 6.35 .250 1.71 .067 REF F:\DWG\MISC\MKTG\BNC7T-J-P-XX-ST-EM1-MKT.SLDDRW PROPRIETARY NOTE 25.48 1.003 REF THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BNC7T EDGE MOUNT STRAIGHT JACK DWG. NO. BNC7T-J-P-XX-ST-EM1 BY: G.HERMAN 01/04/2008 SHEET 2 OF 2
BNC7T-J-P-GN-ST-EM1 价格&库存
很抱歉,暂时无法提供与“BNC7T-J-P-GN-ST-EM1”相匹配的价格&库存,您可以联系我们找货
