MMCX7-J-P-GF-ST-TH1
MMCX7-J-P-GF-ST-TH1
    SAMTEC(申泰)
    插件
    特性:外壳材料:黄铜。绝缘材料:PIFE。接触材料:铍铜。引脚材料:黄铜。工作温度范围:-65°C 至 +125°C。阻抗:75Ω。介电耐压:500Vrms,50Hz。介电工作电压:170Vrms,5...
MMCX7-J-P-GF-ST-TH1 数据手册
REVISION E Pb THIS PRODUCT MANUFACTURED WITH LEAD-FREE PROCESSING DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] MMCX7-J-P-XX-ST-TH1 TERMINATION -TH1: THROUGH HOLE DO NOT SCALE FROM THIS PRINT ORIENTATION -ST: STRAIGHT GENDER -J: JACK -B- 3.50 .138 REF (TYP) PLATING SPECIFICATION -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT (SEE TABLE 1) TYPE -P: PCB -A- 0.24 .010 REF 3.50 .138 REF (TYP) 'B' DETAIL 'B' SCALE 20 : 1 C 3.20 .126 REF 1.50±0.10 .059±.004 (SHELL TO SOCKET) 2.30 REF "A" 1 2.70 .106 REF 2 7.40 .291 REF (TYP) 2.05 .081 REF (TYP) MMCX7-J-P-XX-ST-TH1-ASM SHOWN 3 0.40 .016 REF (TYP) POSITION INSULATOR FLUSH TO SHELL +/-0.12 2.65 .104 REF (TYP) C "A" 0.50±0.05 .020±.002 (PTH) 0.50 .020 REF (TYP) 3.00 .118 REF (TYP) 0.30 .012 REF 0.30 A B C 3.00 .118 (TYP) SECTION "A"-"A" RECOMMENDED PCB LAYOUT FIG 1 MMCX7-J-P-XX-ST-TH1-ASM SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE FOR INSULATOR: 22.24N [5.0 LBS]. 3. MINIMUM PUSHOUT FORCE FOR CENTER CONTACT: 11.12N [2.5 LBS]. 4. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-HD-WI-3040-M. TRAY: TY-SMA001-1 COVER: TY-SMA001-2 200 PARTS PER TRAY (2 PARTS PER POCKET) F:\DWG\MISC\MKTG\MMCX7-J-P-XX-ST-TH1-MKT.SLDDRW 3.00 .118 (TYP) 0.84±0.05 .033±.002 (PTH) (4 PLCS) MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL: BRASS SOCKET: BeCu INSULATOR: PTFE SHEET SCALE: 8:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MMCX STRAIGHT THROUGH HOLE, JACK- 75 OHM DWG. NO. MMCX7-J-P-XX-ST-TH1 BY: ALVINW 10/08/2011 SHEET 1 OF 2 REVISION E C POSITION INSULATOR FLUSH TO BODY +/-0.08 IN PROCESS 1 INSERT INSULATOR PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 8:1 F:\DWG\MISC\MKTG\MMCX7-J-P-XX-ST-TH1-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MMCX STRAIGHT THROUGH HOLE, JACK- 75 OHM DWG. NO. MMCX7-J-P-XX-ST-TH1 BY: ALVINW 10/08/2011 SHEET 2 OF 2
