HDBNC-J-P-GN-RA-BH1
HDBNC-J-P-GN-RA-BH1
    SAMTEC(申泰)
    插件
HDBNC-J-P-GN-RA-BH1 数据手册
REVISION D HDBNC-J-P-XX-RA-BHX DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER -J: JACK DO NOT SCALE FROM THIS PRINT TYPE -P: PCB 7.50 .295 REF 0.50 .020 REF 4.25 .167 REF ORIENTATION -RA: RIGHT ANGLE PLATING SPECIFICATION -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT 100µ" NICKEL ON BODY -HN: 30µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT 100µ" NICKEL ON BODY -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT 100µ" NICKEL ON BODY -GN: 10µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT 100µ" NICKEL ON BODY (SEE TABLE 1) 2 (SEE NOTE 4) 1 7.52 .296 REF TERMINATION -BH1: BULKHEAD THROUGH HOLE .062 BOARD -BH2: BULKHEAD THROUGH HOLE .093 BOARD -BH3: BULKHEAD THROUGH HOLE, ROUND LEGS .062 BOARD "B" REF RECOMMENDED PCB LAYOUT "A" REF 1.70 .067 PTH (4 PLCS) 2.55 .100 REF 0.50 .020 REF 20.30 .799 REF 16.55 .652 REF 5.08 .200 (4 PLCS) 12.00 .472 REF 1.67 .066 REF (8 PLCS) 7.00 .276 REF 5.08 .200 (4 PLCS) REF FIG 1 0.76 .030 PTH 2.54 .100 (4 PLCS) 1/4-36 UNS-2A REF 7.50 .295 (4 PLCS) REF RECOMMENDED MOUNTING HOLE 0.92 .036 (4 PLCS) REF -BH1 AND BH2 HDBNC-J-P-XX-RA-BH1 SHOWN 2.95 [.116] MAX PANEL THICKNESS 6.50 .256 5.90 .232 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] NOTES: MATERIAL: 1. C REPRESENTS A CRITICAL DIMENSION. 2. NOTE DELETED. 3. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-HD-WI-3040-M. TRAY: TY-SMA-001-1 COVER: TY-SMA-001-2 4. NUT TO BE PACKAGED SEPARATELY. PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SOCKET: BeCu SHELL, BODY, NUT: BRASS INSULATOR: PTFE c:\enterprisevault\DWG\MISC\MKTG\HDBNC-J-P-XX-RA-BHX-MKT.SLDDRW * SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HD BNC 75 OHM, RA JACK BULKHEAD DWG. NO. HDBNC-J-P-XX-RA-BHX BY: ALVIN W 02/17/2011 SHEET 1 OF 2 REVISION D "B" REF "A" REF 1.35 .053 REF 1.90 .075 REF 5.08 .200 (4 PLCS REF) FIG 2 HDBNC-J-P-XX-RA-BH3 SHOWN SAME AS FIG 1, EXCEPT AS SHOWN 7.52 .296 REF 1.50 .059 REF 1/4-36 UNS-2B REF I CT RE DI ON OF EL T V RA TH R OU GH E NUT SPECIFICATION AV W * RECOMMENDED PROCESSING ORIENTATION PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 c:\enterprisevault\DWG\MISC\MKTG\HDBNC-J-P-XX-RA-BHX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HD BNC 75 OHM, RA JACK BULKHEAD DWG. NO. HDBNC-J-P-XX-RA-BHX BY: ALVIN W 02/17/2011 SHEET 2 OF 2
HDBNC-J-P-GN-RA-BH1 价格&库存
很抱歉,暂时无法提供与“HDBNC-J-P-GN-RA-BH1”相匹配的价格&库存,您可以联系我们找货
HDBNC-J-P-GN-RA-BH1
  • 100+49.37966
  • 500+44.24098
  • 1000+42.43942
  • 2500+39.00558
  • 3000+35.40246
库存:4
HDBNC-J-P-GN-RA-BH1
    • 1+73.32120
    • 10+62.79120
    • 30+56.37600
    库存:3
