SMB/SMC Solder Type Right Angle Plugs for Semi-Rigid Cable
1. Identify connector parts. (2 piece parts – except diecast)
2. Strip cable to dimensions shown. Do not nick center
conductor.
3. Insert cable into body making certain that the cable
insulation bottoms on center contact. Solder center
conductor to contact through the rear and side access
ports. Use a minimum amount of solder for a good joint.
.020 (0.51) diameter solder is recommended.
4. Solder body to cable. Use a minimum amount of heat to
minimize cable insulation movement. Place expansion cap
in access port and set with .125 (3.17) diameter punch.
Snap cover ring over side access port.
Cable Group
RG-405/U (.086 Semi-Rigid)
254
Part No.
131-1693-101
131-1693-116
131-3693-101
131-3693-116
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“131-3693-116”相匹配的价格&库存,您可以联系我们找货
