2020A504-085
2020A504-085
    WINCHESTER(温彻斯特)
    SMP
2020A504-085 数据手册
E-Snap End Launch Page 1 of 2 SMP Connectors SMP connectors are sub miniature RF connectors with snap couplings which offer broadband performance from DC to 40GHz.with a VSWR of 1.18 max. These are one of the smallest series available for RF coaxial applications. The small size allows interconnects on the most miniature of devices, devices with multiple posts where high density is required, where lighter weight end products are essential, and where it is necessary, to fit miniature, and sub miniature cables. PCB versions are available in Limited Detent, Full Detent and Smooth bore. PCB Mount (Limited Detent) SMP Male SMT Vertical 50 ohm 2062AL10111 1 Limited Detent SMP Male SMT Vertical 50 ohm 2062AL12111 2 Limited Detent SMP Male End Launch 50 ohm 2062EL10104 3 Limited Detent PCB Mount (Full Detent) SMP Male SMT Vertical 50 ohm 2062AF10111 1 Full Detent SMP Male SMT Vertical 50 ohm 2062AF12111 2 Full Detent SMP Male End Launch 50 ohm Full 2062EF10104 3 Detent PCB Mount (Smooth Bore) SMP Male SMT Vertical 50 ohm 2062AS10111 1 Smooth Bore SMP Male SMT Vertical 50 ohm 2062AS12111 2 Smooth Bore SMP Male End Launch 50 ohm 2062ES10104 3 Smooth Bore Direct Solder 2020A504SMP Female Direct Solder for .047 4 047 cable 2020A504SMP Female Direct Solder for .085, 4 085 .086 cable RoHS compliant REQUEST QUOTE REQUEST DRAWING http://www.bomarinterconnect.com/SMP.htm 5/23/2013 E-Snap End Launch Fig.4 Fig.1 Page 2 of 2 Fig.2 Fig.3 ___________________________ http://www.bomarinterconnect.com/SMP.htm 5/23/2013
2020A504-085 价格&库存
很抱歉,暂时无法提供与“2020A504-085”相匹配的价格&库存,您可以联系我们找货
