BNC 75Ω connector
BNC75 Series
■Features
1. 50Ω-based BNC connector, 75Ω type
BNC type products are widely used as 50ø
connectors. Hirose’s BNC75 is rated for 75ø and
can be mated with the other BNC connectors.
4. Applicable specifications
Electronic Industries Association of Japan's
temporary specifications
(EIAJ RCX-5233)
2. Easy on, easy-off bayonet lock system
Bayonet lock system that is easy to use and
operate.
3. Applicable cable
Cable for this connector is coaxial with the
diameter of approximately Ø1.5 - Ø6
(1.5C-QEV.CW etc.)
■Functional diagram
Plug side
■Straight plug
Representative product:
BNC(75)-P-59/U(40)
■Cap
CW-123A/U(40)
Jack side
Plug-plug relay adapter
■Adapter
●Mating interface shape
Jack -jack type
BNC(75)-A-JJ (40)
Jack-Jack relay adapter
■ Short plug
JCW-159/U(40)
■Nonreflective terminator
●Mating interface shape: plug type
BNC-TMP-05(75)(50)
■U-link
Plug-plug type
BNC-UPA(75)-35(40)
■Panel jack
Representative product: BNC(75)-BPJ1.5CV-(P)(40)
■Right angle receptacle
●PCB-mounted type
Representative product: BNC(75)-LRPC-6(40)
■Various conversion adapters
■Non-reflective terminator
●Mating interface shape: Jack type
BNC-TMJ-05(75)(50)
2014.11w
1
BNC75 Series●BNC 75Ω connector
■Product Specifications
Nominal characteristic impedance
Rated voltage
Rated frequency
Rated value
Items
75ø
AC150Vrms
DC~3GHz
Operation temperature range
Operating relative humidity
Specifications
-30ç~+60ç
Maximum of 85%
Conditions
1. Contact resistance
Maximum of 6mø
Measured at a maximum of DC 100 mA
2. Insulation resistance
Minimum of 1,000 Mø
Measured at DC 500 V
3. Withstanding voltage
No flashover or dielectric breakdown.
AC 500 V for one minute
4. Voltage Standing Wave Ratio (π) Maximum of 1.3
Up to DC 3GHz
5. Retaining force of a female
contact
Minimum of 0.6N
Measured by a pin gauge of Ø 1.32 mm
6. Mating cycles
Contact resistance: a maximum of 20 mø
500 times
No electrical discontinuity for 1 μs or longer.
7. Vibration Resistance
No damage, crack or looseness of parts.
Frequency: 10 - 500Hz, half amplitude: 0.75mm
2
Acceleration: 98m/s , 3 axis directions, 10
cycles each
2
Acceleration : 490m/s , duration: 11ms
Half-sine, 3 directions, 3 times each
8. Shock resistance
9. Moisture resistance
Insulation resistance: a minimum of 100 Mø (at high temperatures) Temperature: +25ç - +65ç
Humidity: 80 - 96%
Insulation resistance: a minimum of 1000 Mø (when dry)
Left for 240 hours
10. Thermal shock resistance
(-55°C for 30 minutes➝5 - 35°C for a maximum
of 5 minutes➝85°C for 30 minutes
➝5 - 35°C for a maximum of 5 minutes), 5 cycles
11. Corrosion resistance
No heavy corrosion.
In a 5 % salt water solution for 48 hours on end
πSome products may have different specifications from those shown above.
The specification values of the Voltage Standing Wave Ratio (V.S.W.R.) are the values measured in the measuring system shown in the
Figure below:
Network Analyzer
Test Set
Test Port
D.U.T
Test Post Cable
Termination
■Material
Parts
Materials
Finish
Remarks
Shell
Brass
Silver plating/nickel plating
Male contact
Brass
Silver plating/gold plating
Female contact
Beryllium copper
Insulator
PTFE resin
Flame retardant
Gasket
Silicone rubber
■Ordering information
BNC ( 75 ) - L
q
2
w
P - 59/U
e
r
1 Series name: BNC(75)
:Complies with BNC75ø
2 Shape of connectors
None: Straight type
L: Right angle type
B: Bulk head type
3 Connector type
P: Plug
PJ: Panel jack
R: Receptacle
PA: Panel adapter
4 1) For plug / jack
··Applicable cable
2) For receptacle
PC: PCB-mounted type
3) For adapter
: Mating interface shape
4) All other cases
··additional number
■Plugs
Ø14.5
Ø6.55
Ø11.1
●Straight plug
Part No.
(26)
BNC(75)-P-59/U(40)
HRS No.
302-0292-5 40
Applicable cables RoHS
Yes
RG-59/U
Ø5.8
(14.5)
●Panel jack (nut securing type)
Part No.
HRS No.
Applicable
cables
Mounting
hole
RoHS
dimension
Remarks
Ships with
Ø15
BNC(75)-BPJ-1.5CW-2(40) 302-0343-4 40
14
1.5C-2W
26
Ø16
Part No.
11.65
17.2
23.2
HRS No.
12.5
23.2
11.0
(HEX)
Yes
2-2
BNC(75)-BPJ-1.5CV-(P)(40) 302-0369-8 40
Mounting
hole
RoHS
dimension
Applicable
cables
Remarks
1.5C-2V
Ships with hex nut
Ships with round nut
BNC(75)-BPJ-1.5CV-1(40) 302-0375-0 40 1.5C-2V
(refer to Note)
BNC(75)-BPJ-1.5CW(P)(40) 302-0388-2 40 1.5C-2W Ships with hex nut
(Note) Requires dedicated jigs.
πThe shape diagram is a representative example.
Ø13
15
toothed lug
terminal strip
Part No.
HRS No.
Applicable
cables
BNC(75)-BPJ-1.5CV-2(40)
302-0380-0 40
1.5C-2V
2-1
Yes
Mounting
hole
RoHS
dimension
3-1
Yes
3
■ Receptacles
11
Right angle receptacle (PCB-mounted type)
4-
1
Mounting hole
RoHS
dimension
Part No.
HRS No.
BNC(75)-LR-PC-6(40)
302-0363-1 40
11
29.9
4-1
Yes
■ Adapters
Ø15
Straight adapter
Part No.
32.54
HRS No.
RoHS
302-0384-1 40
Yes
Part No.
HRS No.
RoHS
BNC-UPA(75)-35(40)
302-0301-4 40
Yes
BNC(75)-A-JJ(40)
27.1
U-link (Mating interface shape: plug-plug)
35(Movable distance ±1.5)
Ø13
Ø2.4
Conversion adapter ( BNC (75) jack to H. FL jack panel adapter)
12.5
21.3
11.0
(HEX)
Part No.
HRS No.
BNC(75)J-H.FLJ-BPA(40)
311-0302-8 40
Mounting hole
RoHS
dimension
3-1
Yes
Conversion adapter (BNC (75) jack to PL71 jack panel adapter)
17.2
27.9
Ø16
Ø3.95
15.0
(HEX)
Part No.
HRS No.
BNC(75)J-PL71J-BPA(40)
311-0304-3 40
Mounting hole
RoHS
dimension
2-1
Yes
4
■ Nonreflective terminator
HdaYZg^c\
Part No.
HRS No.
BNC-TMP-05(75)(50)
353-0100-5 50
21
19.5
4.5
Ø12
Soldering
Part No.
HRS No.
BNC-TMJ-05(75)(50)
353-0101-8 50
Mounting hole dimension diagram (BNC75Ω connector)
1
2
ØA
ØB
ØA
ØA
B
B
1C
1D
B
4-ØA
4
3
4-ØC
2C
2D
Diagram 1
Attached
diagram
No.
1-1
1
1-2
4.13
B
+ 0.05
C
Attached
diagram
3-1
4-1
12.7
3
3
12.7
3.2
4
3
12.8
+ 0.1
+ 0.1
11.3
+ 0.1
+ 0.1
Diagram 3
D
2-1
1-3
2
A
Diagram 2
12.7
No.
Diagram 4
B
A
9.6
+ 0.1
+ 0.1
+ 0.1
+ 0.1
C
D
5.08
± 0.05
10.16
± 0.05
5
High-frequency characteristic of 75Ω hirose product series
BNC (75) Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
BNC(75)-BPJ-1.5CV-※
1.2
1.1
1
1
1.5
2
2.5
3
2
2.5
3
2
2.5
3
2
2.5
3
Frequency [GHz]
PL71 Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
PL71-LP-1.5C(40)
1.2
1.1
1
1
1.5
Frequency [GHz]
PL75 Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
PL75-LP-1.5CV
1.2
1.1
1
1
1.5
Frequency [GHz]
H.FL75 Series
2
1.9
1.8
H.FL75-2LPG-084N※-L
V.S.W.R.
1.7
100
1.6
1.5
1.4
1.3
1.2
1.1
1
1
1.5
Frequency [GHz]
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“BNC(75)-P-59/U(40)”相匹配的价格&库存,您可以联系我们找货
