Description
Body
Pin
Insulation
Lock Washer
Spacer
Support
Heat Shrink
Material
Brass
BE CU
PTFE
BE CU
PTFE
Brass
Polyolefin
Finish
Gold
Gold
N/A
Gold
N/A
Gold
Black
REVISIONS
REV
B
DESCRIPTION
DATE
APPV
Added new title block and heat shrink; Updated instructions 12-JUL-12
SAH
SIDE VIEW
PIN
Ø0.157
(4.00) Ø0.093
(2.35)
Ø0.078
(2.00)
0.104
(2.65)
0.224
(5.70)
Ø0.016
(0.40)
0.104
(2.65)
SPACER
SUPPORT
Ø0.031
(0.80)
0.228
(5.80)
0.199
(5.05)
0.528
(13.40)
HEAT SHRINK
Ø0.118
(3.00)
CONMMCX007-R178 ASSEMBLY INSTRUCTIONS
1.
2.
3.
4.
5.
6.
7.
8.
Strip the cable to the recommended dimensions.
Slip heat shrink onto stripped cable.
Solder the support onto the braid.
Place the spacer onto the center conductor.
Solder or crimp the pin onto the center conductor.
Insert the pin, center conductor, spacer, and support into the body
until the pin snaps in.
Crimp the tail of the body onto the support with a 0.093” hex crimp tool
(or one labeled for use with RG-178 cable).
Use heat shrink to cover crimp.
RECOMMENDED CABLE STRIPPING DIMENSIONS
0.079 0.094
(3.60) (0.80)
0.197
(5.00)
RG-178 Cable
0.787
(20.00)
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
159 ORT LANE
MERLIN, OR 97532
TITLE:
MMCX MALE CABLE END CRIMP
FOR RG178 CABLE
SIZE DWG. NO.
DRAWN: B.MURPHY DT: 12-JUL-12
ENGR: S.HOGAN
DT: 12-JUL-12 SCALE: 2:1
REV
CONMMCX007-R178
DO NOT SCALE DRAWING
B
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONMMCX007-R178”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+39.40920
- 200+15.72480
- 500+15.20640
- 1000+14.94720
