3321-60001
3321-60001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN1.85MMJCKSTR50OHMEDGEMT
3321-60001 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION DATE APPROVED 01 PRELIMINARY 02/12 STW - RELEASE 01/13 PJS A DCN 39649 02/13 STW REV .500 12.70 .320 8.13 .180 4.57 .075 1.91 .068 1.73 .120 3.05 .295 7.49 .215 5.46 .012 0.30 M7 X .75-6g MATERIAL: BODY & INSERT: .074 1.88 .060 1.52 .070 1.78 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULAOTR: PCTFE PER ASTM D1430 NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: BODY, INSERT & CONTACT: GOLD PER ASTM B 488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: FREQ.RANGE: VSWR: MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: DC TO 65.0 GHz 1.33:1 MAX. DC TO 65.0 GHz. N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 02/10/12 CHECKED: APPROVED: STW 02/10/12 STW 02/10/12 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 1.85 MM JACK PCB MOUNT Ø.012 PIN FOR .062" PCB SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 3321-60001 SHEET 1 OF 1
3321-60001 价格&库存
很抱歉,暂时无法提供与“3321-60001”相匹配的价格&库存,您可以联系我们找货
  • 1+817.923691+106.01849
