Right Angle SMA Low Loss Diameter .195, .200 and .240
1. Identify connector parts. (3 piece parts)
2. Strip cable to dimensions shown. Do not nick braid, foil or center
conductor. Cut foil flush with dielectric, do not remove foil. Make
sure that dielectric is clean and free from all particles. Tin center
conductor, keeping solder amount to a minimum. Slide crimp
sleeve onto jacket of cable.
3. Flare braid and slide body assembly over foil and dielectric, then
under braid. Make sure cable center conductor is contained
within connector contact, but do not allow foil and dielectric
to enter body access port. Solder center conductor to contact
through the rear access port. Use a minimum amount of solder
for a full fillet joint. .020 (0.51) Diameter solder is recommended.
4. Arrange braid uniformly around crimp stem. Slide crimp sleeve
forward and crimp using Johnson hand crimp tool 141-0000913 and recommended crimp die hex. Place expansion cap in
access port and seat with recommended Diameter flat punch.
Low Loss
Diameter
“A”
Crimp Die Hex
Flat Punch Diameter
0.195
.110 (2.79)
.213 (5.41) hex
.187 (4.75)
0.200
.110 (2.79)
.213 (5.41) hex
.187 (4.75)
0.240
.135 (3.43)
.255 (6.48) hex
.242 (6.15)
Cable Group
Part No.
Crimp Hex
LMR-195
142-0407-101
142-0407-106
.213 (5.41)
.213 (5.41)
LMR-200
142-4439-101
142-4439-106
.213 (5.41)
.213 (5.41)
LMR-240
142-0435-101
142-0435-106
.255 (6.48)
.255 (6.48)
LMR-195
142-5407-101
142-5407-106
.213 (5.41)
.213 (5.41)
LMR-200
142-0439-101
142-0439-106
.213 (5.41)
.213 (5.41)
LMR-240
142-5435-101
142-5435-106
.255 (6.48)
.255 (6.48)
LMR-195
142-4407-101
142-4407-106
.213 (5.41)
.213 (5.41)
LMR-200
142-5439-101
142-5439-106
.213 (5.41)
.213 (5.41)
LMR-240
142-4435-101
142-4435-106
.255 (6.48)
.255 (6.48)
249
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0407-101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+229.236781+29.74329
- 10+194.8459410+25.28110
- 25+182.6500725+23.69870
- 50+173.9339650+22.56779
- 100+165.63619100+21.49116
- 250+155.27684250+20.14704
- 500+147.87574500+19.18676
