kwiQMAte™ Crimp Type Right Angle Plugs for Flexible Cable
1. Identify connector parts. (3 piece parts)
2. Strip cable to dimensions shown. Do not nick braid or
center conductor. Twist stranded center conductor into
tight bundle and tin (optional). Slide crimp sleeve onto
cable as shown.
3. Flare braid and slide cable into body making certain
that the cable dielectric bottoms on center contact.
Solder center conductor to contact through the rear
access port. Use a minimum amount of solder for a full
fillet joint. .020 (0.51) diameter solder is recommended.
4. Arrange braid uniformly around crimp stem. Slide
crimp sleeve over braid and crimp securely using
recommended crimp tool. Place expansion cap in
access port and seat with .187 (4.75) diameter flat
punch. Shrink heat shrink tubing over crimp sleeve if
applicable.
Cable Group
Part No.
Crimp Hex
RG-316
146-0403-107
.128 (3.25)
RG-316 DS
146-0404-107
.151 (3.83)
275
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“146-0403-107”相匹配的价格&库存,您可以联系我们找货
