Type N Straight Plug Solder Style for Semi-Rigid Cable
1. Identify connector parts (2 piece parts) and tools (5 piece
parts).
2. Strip cable jacket and dielectric to dimension shown. Do
not nick center conductor. Clean all debris from cable.
3. Place plug contact onto center conductor, insert
appropriate sized solder shim between cable jacket and
contact.
4. Insert contact into location fixture and clamp cable in vise.
Tighten stop screw until light pressure is applied between
contact, solder shim and cable jacket.
5. Solder contact to center conductor through solder hole
using .020 (.051) diameter flux core solder wire. Use a
minimum amount of solder for a good joint.
6. After solder joint has cooled, loosen stop screw and
remove solder shim. Remove cable from vise and remove
any excess solder from contact with a sharp blade and
clean all debris from contact and cable.
7. Insert contact and cable into plug connector assembly,
making sure cable jacket bottoms out against internal
shoulder of connector assembly. Insert location fixture into
connector assembly and clamp cable in vise. Tighten stop
screw until light pressure is applied between connector
assembly and cable jacket.
8. Solder connector body to cable jacket, using a minimum
amount of solder for a full fillet joint. Allow assembly to
cool before removing connector from vise.
Cable Group
Part No.
“A”
RG-405, .086 Semi-Rigid
138-4693-001
.085 (2.16)
RG-402, .141 Semi-Rigid
138-4694-001
.085 (2.16)
RG-401, .250 Semi-Rigid
138-4696-001
.100 (2.54)
Assembly
Tool
138-4693-001
138-4694-001
138-4696-001
Solder Shim
140-0000-984
140-0000-984
140-0000-985
Location Fixture
140-0000-983
140-0000-983
140-0000-983
Cable Vise
140-0000-962
140-0000-962
140-0000-962
Clamp Inserts
140-0000-964
140-0000-965
140-0000-986
266
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“138-4694-001”相匹配的价格&库存,您可以联系我们找货
