BNC7T-J-P-GN-RA-BH2D
    SAMTEC(申泰)
    插件
BNC7T-J-P-GN-RA-BH2D 数据手册
REVISION D Pb THIS PRODUCT MANUFACTURED WITH LEAD-FREE PROCESSING BNC7T-J-P-XX-RA-BH2D DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER -J: JACK DO NOT SCALE FROM THIS PRINT TERMINATION -BH2D: DIE-CAST BULKHEAD THROUGH HOLE ORIENTATION -RA: RIGHT ANGLE TYPE -P: PCB PLATING SPECIFICATION -HN: HEAVY GOLD/NICKEL TAIL (SEE NOTES 4 & 5) (SUB-BNC7T-J-P-HN-RA-BH2-D) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) BTNC-NUT-003-X -GN: GOLD/NICKEL TAIL (SEE NOTES 4 & 5) (SUB-BNC7T-J-P-GN-RA-BH2-D) (BTNC-NUT-003-N) (BTNC-LWAS-001-N) BTNC-LWAS-001-X RECOMMENDED MOUNTING HOLE 4.00[.157] MAX. PANEL THICKNESS R6.38 [.251] 11.18 .440 SUB-BNC7T-J-P-XX-RA-BH2-D 11.18 .440 RECOMMENDED PCB LAYOUT 7.40 .291 3.70 .146 1.35 .053 PTH (4 PLCS) FIG 1 BNC7T-J-P-XX-RA-BH2D SHOWN 2.54 .100 5.08 .200 1.32 .052 NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. RoHs COMPLIANT. 3. SEE CO-HD-WI-3040-M RF PACKAGING STANDARD FOR PACKAGING INSTRUCTIONS. PRODUCT TO BE PACKAGED IN TRAY TY-BNC002-1 WITH COVER TY-BNC002-2. NUT AND WASHER TO BE BULK PACKAGED SEPARATELY. 4. COMPONENT PLATING DESIGNATIONS: -H: 0.000030" MIN. GOLD OVER 0.000050" MIN. NICKEL. -G: 0.000010" MIN. GOLD OVER 0.000050" MIN. NICKEL. -N: 0.000100" MIN. NICKEL. 5. ASSEMBLY PLATING DESIGNATIONS: -HN: (CENTER CONTACT)-H (OUTER CONTACT) -N (REMAINING METAL PARTS) -N -GN: (CENTER CONTACT)-G (OUTER CONTACT) -N (REMAINING METAL PARTS) -N F:\DWG\MISC\MKTG\BNC7T-J-P-XX-RA-BH2D-MKT.SLDDRW FRONT OF PCB 1.17 .046 PTH UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 5 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL: ZINC NUT,WASHER: BRASS CONTACT: COPPER ALLOY DIELECTRIC: TPX SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BNC RIGHT ANGLE JACK ASSEMBLY DWG. NO. BNC7T-J-P-XX-RA-BH2D BY: B. COOPER 11/5/2009 SHEET 1 OF 2 REVISION D 2.54 .100 REF 1/2-28 UNEF 2B REF 2.59 .102 REF 1.00 .039 SQ. (4 PLCS) REF 2.49 .098 REF 13.90 .547 REF 10.80 .425 REF 13.40 .528 REF 2.54 .100 REF 14.30 .563 REF 3.70 .146 REF 7.40 .291 REF DETAIL 'A' SCALE 3 : 1 9.65 .380 REF CL CL 3.18 .125 REF 0.50 .020 16.00 .630 REF 29.00 1.142 REF 18.95 .746 REF 24.24 .954 REF 13.00 .512 REF 8.80 .346 REF 'A' 8.40 .331 REF 1.00 .039 REF 4.50 .177 REF 4.00 .157 REF 4.00 .157 REF * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\BNC7T-J-P-XX-RA-BH2D-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BNC RIGHT ANGLE JACK ASSEMBLY DWG. NO. BNC7T-J-P-XX-RA-BH2D BY: B. COOPER 11/5/2009 SHEET 2 OF 2
BNC7T-J-P-GN-RA-BH2D 价格&库存
很抱歉,暂时无法提供与“BNC7T-J-P-GN-RA-BH2D”相匹配的价格&库存,您可以联系我们找货
  • 2+36.580402+4.73865
库存:23
  • 10+61.4117810+7.95533
  • 25+53.6871825+6.95468
  • 100+39.76507100+5.15120
  • 250+39.28847250+5.08946
库存:255
  • 1+68.035001+8.81330
  • 25+59.0036025+7.64340
  • 50+49.8884050+6.46260
  • 100+36.29330100+4.70150
  • 500+35.94600500+4.65650
  • 2500+33.933702500+4.39580
库存:1667
  • 1+61.796981+8.00523
  • 25+53.5754425+6.94020
  • 50+45.3539050+5.87518
  • 100+35.95331100+4.65742
库存:23
