SF3321-60011
SF3321-60011
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN1.85MMJKSTR50OHMCOMPRES
SF3321-60011 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV 01 PRELIMINARY DATE APPROVED 11/12 STW .225 5.72 2X .102 2.59 .625 15.88 .003 0.08 M7X.75-6g .168 4.27 A .480 12.19 .020 0.51 MATERIAL: BODY & INSERT: CONTACT: .005 0.13 DETAIL A SCALE 12 : 1 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 .065 1.65 .438 11.13 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 .441 11.20 INSULATOR: PCTFE PER ASTM D1430 FINISH: BODY & INSERT: CONTACT: PASSIVATED PER AMS-2700. GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: PERFORMANCE: FINISH: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: 50 OHMS DC TO 65.0 GHz 1.33:1 DC TO 65.0 GHz .05 X SQRT(F(F IN GHz)) SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 11/13/12 CHECKED: APPROVED: STW 11/13/12 STW 11/13/12 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 1.85MM JACK 2 HOLE FLANGE COMPRESSION MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF3321-60011 SHEET 1 OF 1
SF3321-60011 价格&库存
很抱歉,暂时无法提供与“SF3321-60011”相匹配的价格&库存,您可以联系我们找货
