MS-162
MS-162
    HRS(广濑)
    CONN COAX JACK STR 50 OHM SMD
MS-162 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. NEW Miniature Interface Coaxial Switch, DC to 10 GHz MS-162 Series ■Overview Designed to be used as the interface antenna connection for portable terminal devices as well as circuit testing on microwave boards (DC to 10GHz) the coaxial switch offers high performace, low loss, extremely high durability and reliability, in a small and lightweight package. Normally closed, the circuit is re-directed to the plug side by the mating of the plug with the receptacle. ■Features Comparison with the existing MS-147 1. Low insertion loss 0.08 dB typical at 1 GHz 0.12 dB typical at 2 GHz (not mated with the plug) MS-147 MS-162 ■Footprint 39.6mm2 2. Space-saving design 3.5 mm x 3.1 mm occupied board space. 14.0mm2 6.0 4.0 5.4 3.5 3. Low profile 3.5 3.1 5.8 6.6 2.5 mm max. protrusion above the board. 4. Lightweight 0.044 g total weight 5. Durability 12, 000 mating/unmating cycles, with corresponding plug. MAX 2.5 MS-162 (Receptacle) contact has nickel plating areas to prevent solder wicking into critical areas. ■Height 3.9 6. Critical area protection 65% saving of space 7. Board placement with automatic equipment. Packaged on tape-and-reel. 36% lower profile 8. Self alignment When mating, plug and receptacle will self align in horizontal axis within 0.5mm. ■Weight 0.11g 9. RoHS compliant 0.044g 60% lighter weight All components and materials comply with the requirements of the EU Directive 2002/95/EC. ●Plugs ●SMA conversion adapter ■Applications *Wireless communication modules (Bluetooth, WLAN, UWB, ZigBee) *Portable terminals, notebook computers, ETC, POS terminals, GPS terminals, PDA, and any small devices requiring verification of antenna/circuit performance and re-direction of the transmission. MS-162-C(LP)-1 MS-162-HRMJ-1 2006.2 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Product Specifications Not mated with the plug Open (Mated with MS-162-HRMJ-1) Operating temperature range –40ç to +85ç Rated power 4W Frequency range DC to 10GHz V.S.W.R. Insertion loss Isolation loss 1.2 max. (DC to 3GHz) 1.2 max. (DC to 3GHz) 1.5 max. 1.7 max. (3GHz to 6GHz) (6GHz to 10GHz) 1.6 max. 1.7 max. (3GHz to 6GHz) (6GHz to 10GHz) 0.15 dBmax. (DC to 2GHz) 0.2 dBmax. (DC to 2GHz) 0.20 dBmax. 0.40 dBmax. (2GHz to 3GHz) (3GHz to 6GHz) 0.3 dBmax. 0.5 dBmax. (2GHz to 3GHz) (3GHz to 6GHz) 0.70 dBmax. (6GHz to 10GHz) 0.7 dBmax. (6GHz to 10GHz) ——————— Item 100 mA 2. Insulation resistance 1000 Mø min. 100 V DC 3. Withstanding voltage No flashover or insulation breakdown 100 V AC / 1 minute No electrical discontinuity of 10 µs or more No electrical discontinuity of 10 µs or more Contact resistance: 100 mø max. 6. Humidity Insulation resistance: 10 Mø min. 7. Thermal shock (1GHz to 3GHz) (3GHz to 6GHz) 12 dBmin. (6GHz to 10GHz) Conditions 100 mø max. 5. Shock (DC to 1GHz) 20 dBmin. 14 dBmin. Specification 1. Contact resistance 4. Vibration 25 dBmin. Contact resistance: 100 mø max. Insulation resistance: 10 Mø min. Frequency: 10 to 55 Hz, single amplitude of 1.5 mm, 2 hours in each of the 3 axis. Acceleration of 490 m/s2, 6 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. 96 hours at 40ç, RH of 90% to 95% Temperature: –55ç / +5ç to +35ç / +85ç / +5ç to +35ç Time: 30 /+ 5 max. / +30 / +5max. (Minutes) 100 cycles 8. Durability (mating/un-mating, with Contact resistance: 100 mø max. 12, 000 cycles corresponding plug) ■Materials Part 2 Material Finish Remarks Shell Brass Gold plated —————— Insulators Polyamide —————— UL94V-0 Common terminal Beryllium copper Partially gold plated (Nickel barrier) —————— Antenna terminal Phosphor bronze Partially gold plated (Nickel barrier) —————— The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BHigh Frequency Characteristics (Typical) ●NORMALLY CLOSED(N.C) ~ (Not mated with the plug) [dB] 0.0 INSERTION LOSS 0.4 0.6 0.8 1.8 V.S.W.R. INSERTION LOSS 0.2 1.6 1.4 V.S.W.R. 1.2 0 2 4 8 6 1.0 10 [GHz] ●OPEN(N.O) ~ (Mated with the plug) [dB] 0.0 0.4 0.6 0.8 INSERTION LOSS 1.8 V.S.W.R. INSERTION LOSS 0.2 1.6 1.4 V.S.W.R. 1.2 0 2 4 6 8 1.0 10 [GHz] 8 10 [GHz] [dB] 0 ISOLATION 10 20 ISOLATION 30 40 0 2 4 6 3 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle 3.1 2.4 3.5 B Ø2.8 2.48 1.88 1 0.61 0.3 Part Number CL No. Packaging MS-162 358-0208-3 MS-162 (01) 358-0208-3-01 C RoHS 3, 000 pieces/reel YES 100 pieces/bag G G A 0.4 BCircuit diagram Not mated with the plug (N.C) G G Mated with the plug (N.O) G G A A B C B C G G G G MS-162 Plug MS-162 MS-162 Plug MS-162 BPCB mounting pattern and metal mask dimensions PCB mounting pattern Metal mask dimensions 2.4 0.6 3.5 2.8 0.5 0.62 area show the conductive pattern prohibited area. 4 0.65 0.5 0.62 0.65 0.8 3.5 2.8 0.65 0.6 0.65 4 4 2.4 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Plug ■SMA conversion adapter CL No. RoHS Part Number CL No. RoHS 358-0222-4 YES MS-162-HRMJ-1 358-0210-5 YES Ø7 6.3 Part Number MS-162-C(LP)-1 13.7 1/4-36UNS-2A 12 24.29 13.6 2.4 6.29 6 Ø1.8 10.2 Ø4 Ø4 Applicable cable: 1.5D-HQEW, 1.5D-QEW (Fujikura Ltd.) BRecommended Temperature profile Temperature (ç) 10 sec. max. 240 200 160 150 ●Typical Solder Paste q Maximum temperature : 240ç w Peak temperature : 200ç to 235ç e Peak temperature time : 10 sec. max. r 200ç min. : 50 sec. max. t 150ç to 160ç : 40 sec. min. Metal mask thickness: 0.12mm Reflow cycles: 2 cycles 100 0 40 sec. min. Temperature (ç) Time (sec.) 50 sec. max. 5 sec. max. 260 ●Typical Lead-free Solder Paste q Maximum temperature : 260ç 220 w Peak temperature : 240ç to 255ç 200 e Peak temperature time : 5 sec. max. r 220ç min. : 50 sec. to 80 sec. t 180ç to 200ç : 120 sec. max. 180 Metal mask thickness: 0.12mm Reflow cycles: 2 cycles 100 0 120 sec. max. Time (sec.) 50 sec. to 80 sec. 5 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BPackaging Specifications ● Reel dimensions 8 4 12.4 .5 Unreeling direction Ø1 1.75 2 Ø1 3.25 BRecommended Nozzle Dimensions Ø1 Ø1.5 Ø3 6 Ø80 Ø180 12 5.5 3 Unreeling direction The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BExample of Application Installed in portable devices O-ring Note 1: When mounting the MS-162-C(LP)-1 make sure that the recommended self alignment distances and angle can be maintained. Note 2: When fully mated the spring force F must be 10N to 15N. F Installed in test fixture Floating mounting plate (Plug side) Retaining plate Pressure plate moves vertically Mounting screw A F To measuring instrument View A Tilt prevention Load F MS-162-C(LP)-1 Load 0.5min. Clearance Stop MS-162-C(LP)-1 MS-162 Board 0.5min. Clearance Self-centering Mounting screw Cable termination Retaining plate The retaining plate cannot protrude and interfere with the cable termination areas. Note 1: When mounting the MS-162-C(LP)-1 make sure that the recommended self alignment distances and angle can be maintained. Note 2: When fully mated the spring force F must be 10N to 15N. Axial misalignment distance Allowable angular misalignment for mating ±2.5° 0.5mm Plug MS-162-C(LP)-1 Receptacle 7 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BPrecautions 1. Do not use the washing process. 2. Do note use hand soldering for mounting of MS-162. 3. When using a heat gun, hot plate, or similar methods, limit the temperature to 260ç applied for 10 seconds max. 4. Consult Hirose if your application, installation methods or end-user environment are different than the recommended. 5. Please refrain from using the product in environments specifically affected by dust, high humidity, gases, very high temperatures and very low temperatures. 6. When used as an RF interface of a portable terminal, consider using a rubber cap or other means of protection against intrusion of dust, dirt or other harmfull elements. 7. When using, assure that the plug is fully inserted to the surface (P), as shown. P ® 8 5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN PHONE: 81-3-3491-9741, FAX: 81-3-3493-2933 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of publication. Contents are subject to change without notice for the purpose of improvements.
MS-162 价格&库存
很抱歉,暂时无法提供与“MS-162”相匹配的价格&库存,您可以联系我们找货
