CONREVSMA011-R178
CONREVSMA011-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA011-R178 数据手册
Description Body Pin Insulation Spacer Gasket Support Heat Shrink Material Brass BE CU PTFE PTFE SI Rubber Brass Polyolefin Finish Nickel Gold N/A N/A Rubber Gold Black REVISIONS REV A B 1/4-36UNS-2A THREADS DESCRIPTION DATE New frame; add heat shrink; Updated drawing and dimensions; Added new title block APPV 4/26/10 CJ 2-JUL-12 SAH 0.327 (8.30) Ø0.209 [5.30] 0.106 [2.70] Ø0.049 (1.25) H0.252 [6.40] PIN 0.252 [6.40] 0.197 [5.00] SPACER SUPPORT 0.571 [14.50] Ø0.118 [3.00] SIDE VIEW CONREVSMA011-R178 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. 7. 8. Strip cable to recommended dimensions. Slip heat shrink onto stripped cable. Solder the support onto the braid. Place the spacer onto the center conductor. Solder or crimp the pin onto the center conductor. Insert the pin, center conductor, spacer, and support into the body until the top of the pin is even to end of the body. Crimp the tail of the body onto the support with a 0.093” hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. 0.098 [2.50] 0.177 [4.50] RG-178 Cable RECOMMENDED CABLE STRIPPING DIMENSIONS HEAT SHRINK NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: 0.211 [5.35] 0.787 [20.00] FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: B.MURPHY DT: 2-JUL-12 ENGR: S.HOGAN DT: 2-JUL-12 159 ORT LANE MERLIN, OR 97532 TITLE: RP-SMA FEMALE CABLE END CRIMP FOR RG-178 CABLE SIZE DWG. NO. REV CONREVSMA011-R178 SCALE: 2:1 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA011-R178 价格&库存
很抱歉,暂时无法提供与“CONREVSMA011-R178”相匹配的价格&库存,您可以联系我们找货
