626N518
626N518
    WINCHESTER(温彻斯特)
    MINI UHF BLKHD JACK
626N518 数据手册
Specifications for Mini-UHF _____________________________ s MATERIALS Connector Parts Material Connector Body and Parts Brass Male Contact Pin Brass Outer Contact Brass Crimp Ferrule Annealed Copper Insulators Delrin Plating Nickel ELECTRICAL Requirement Performance Impedance Non Constant Frequency Range 0-2 GHz VSWR 1.25 Max. Working Voltage (At Sea level) 335V rms Insulation Resistance 5000 Megohm Min. Dielectric 1000V at 60Hz, rms Withstanding Voltage (For 1 Minute) MECHANICAL & ENVIRONMENTAL Requirement Durability Cable Retention (Cable Types) Performance 500 Matings 40 lbs. Minimum Pull Test Coupling Nut 45 lbs. Maximum Temperature Range Delrin: -55 to +85C s _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 s Back to Index 20 - Page 21 - Mini - UHF Connectors _____________________________ Crimp Plugs Mini-UHF cable plugs are available in three-piece crimp and also twist-on versions to satisfy the installer’s preference. Two cable diameters are facilitated with these connectors for applicable applications. Part Number Description RG/U Fig. Cable No. 610A608F Crimp Plug 58 97 610A608G Crimp Plug 59, 62 97 610A405F Twist-On Plug 58 98 Fig. 97 RoHS compliant REQUEST DRAWING Fig. 98 REQUEST QUOTE s s Jacks Two cable jacks and one panel jack style are available as standard items. The cable jacks utilize the crimp method of assembly and the panel jack will facilitate any cable size by soldering the center conductor to the connector’s solder-cup contact. s Fig. 99 Fig. 100 Part Number Description RG/U Fig. Cable No. 620A608F Cable Jack, 58 99 620A608G Cable Jack, 59, 62 99 626N518 Bulkhead Panel Jack, Solder Cup RoHS compliant REQUEST DRAWING Any 100 REQUEST QUOTE Adapters Standard configurations of adapters are machined brass with attractive nickel plating. All contacts are gold plated brass (males) and phosphor bronze (females). Part Number Description Fig. No. 631A505 Male/Male 101 632U508 Female/Female Inline 102 643A505 F/M/F “T” Adapter 103 645A505 F/F/F “T” Adapter 104 651A505 F/M Right Angle Adapter 105 RoHS compliant REQUEST DRAWING REQUEST QUOTE Fig. 101 s Fig. 102 Fig.103 Fig. 104 Fig. 105 _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 s - Page 22 - Back to Index 21
626N518 价格&库存
很抱歉,暂时无法提供与“626N518”相匹配的价格&库存,您可以联系我们找货
