CONSMA014-R58
CONSMA014-R58
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA014-R58 数据手册
Description Body Socket Insulation O-Ring Crimp ring Washer Nut Heat Shrink 1/4"-36UNS-2A THREADS Material Brass Brass PTFE SI Rubber Brass Brass Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Nickel Nickel Black 0.098 [2.50] 0.098 [2.50] REVISIONS 0.276 [7.00] REV RG-58 Cable B DESCRIPTION Updated footprint and dimensions; Added new title block DATE APPV 10-JUL-12 SAH Ø0.287 [7.30] RECOMMENDED CABLE STRIPPING DIMENSIONS FLAT 0.228 [5.80] H0.433 [11.00] Ø0.177 [4.50] PIN CHUCK 0.2x2x2mm GROOVE Ø0.236 [6.00] Ø0.020 [0.50] 0.984 [25.00] Ø0.024 Ø0.049 [0.60] [1.24] 0.354 [9.00] HEAT SHRINK SOCKET 0.276 [7.00] 0.417 [10.60] 0.083 [2.10] Ø0.256 [6.50] Ø0.402 [10.20] 0.327 [8.30] H0.315 [8.00] 1/4-36UNS-2B THREADS 0.500 [12.70] 0.234 [6.00] 0.748 (21.00) Ø0.236 [6.00] SIDE VIEW Ø0.358 [9.10] 0.065 [1.65] NUT 0.020 [0.50] CRIMP RING Ø0.256 [6.50] WASHER RECOMMENDED MOUNTING HOLE 0.055 [1.40] NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONSMA014-R58 ASSEMBLY INSTRUCTIONS 1. Strip the cable to recommended dimensions. O-RING THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE 2. Slip heat shrink and crimp ring onto stripped cable. MERLIN, OR 97532 TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS 3. Insert o-ring into groove in the nut on body. DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE TITLE: 4. Solder the socket to the center conductor. EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. SMA FEMALE BULKHEAD MOUNT CABLE 5. Insert the socket, center conductor, and insulation into the body. PROJECTION: MATERIAL: TOLERANCES: 6. Wrap the braid around the tail of the body and crimp the ring with END CRIMP WITH O-RING FOR RG58 CABLE .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 0.213" hex crimp tool (or one labeled for use with RG-58 cable). 1.20 [30.0]-4.75 [120.0]= .024 [0.60] SIZE DWG. NO. REV 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 7. Use heat shrink to cover crimp. FINISH: CONSMA014-R58 B 8. Use the nut and washer to secure the connector to a case. DRAWN: B.MURPHY DT: 10-JUL-12 (2.50mm maximum wall thickness) DO NOT SCALE DRAWING SHEET 1 OF 1 ENGR: S.HOGAN DT: 10-JUL-12 SCALE: 2:1 LDCFDLT_A
CONSMA014-R58 价格&库存
很抱歉,暂时无法提供与“CONSMA014-R58”相匹配的价格&库存,您可以联系我们找货
