CONREVSMA011-R58
CONREVSMA011-R58
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA011-R58 数据手册
Description Body Pin Insulation Gasket Crimp Ring Heat Shrink Material Brass Brass PTFE SI Rubber Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Black REVISIONS REV B DESCRIPTION Updated footprint and dimensions; Added new title block DATE APPV 2-JUL-12 SAH Ø0.256 [6.50] 1/4-36UNS-2A THREADS 0.500 [12.70] 0.339 [8.60] Ø0.209 [5.30] Ø0.126 Ø0.177 [3.20] [4.50] H0.252 [6.40] CRIMP RING Ø0.049 [1.25] Ø0.035 [0.90] Ø0.287 [7.30] PIN 0.252 [6.40] 0.276 [7.00] 0.654 [16.60] 0.984 [25.00] SIDE VIEW HEAT SHRINK CONREVSMA011-R58 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. Strip cable to recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Solder the pin to the center conductor. Insert the pin, center conductor, and insulator into the body. Wrap the braid around the tail of the body and crimp the ring with a 0.213" hex crimp tool (or one labeled for use with RG-58 cable). Use heat shrink to cover crimp. 0.098 0.091 [2.50] [2.30] 0.256 [6.50] RG-58 Cable : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: RECOMMENDED CABLE STRIPPING DIMENSIONS NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: B.MURPHY DT: 2-JUL-12 ENGR: S.HOGAN DT: 2-JUL-12 159 ORT LANE MERLIN, OR 97532 TITLE: RP-SMA FEMALE CABLE END CRIMP FOR RG-58 CABLE SIZE DWG. NO. REV CONREVSMA011-R58 SCALE: 2:1 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA011-R58 价格&库存
很抱歉,暂时无法提供与“CONREVSMA011-R58”相匹配的价格&库存,您可以联系我们找货
