142-0004-211
142-0004-211
    CINCH
    插件
142-0004-211 数据手册
Crimp Type Straight Cable Termination for Flexible Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin. Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable insulation is flush with bottom of connector. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Cable Group Part No. “A” Crimp Hex RG-178/U, 196 142-0002-221/226 .259 (6.58) .105 (2.67) RG-316/U, 161, 174, 179, 187, 188 142-0003-201/206 142-0003-231/236 142-0003-241/246 .312 (7.92) .259 (6.58) .259 (6.58) .128 (3.25) .128 (3.25) .128 (3.25) RG-316 DS, 188 DS 142-0004-201/206 142-0004-211/216 142-0004-221/226 .312 (7.92) .259 (6.58) .259 (6.58) .151 (3.83) .151 (3.83) .151 (3.83) Crimp Type Right Angle Cable Termination for Flexible Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin. Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable insulation is flush with bottom of connector body. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Cable Group Part No. Crimp Hex RG-316/U, 161, 174, 179, 187, 188 142-0003-301/306 .128 (3.25) RG-316 DS, 188 DS 142-0004-301/306 .151 (3.83) 272 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0004-211 价格&库存
很抱歉,暂时无法提供与“142-0004-211”相匹配的价格&库存,您可以联系我们找货
