The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
NEW
Miniature Interface Coaxial Switch, DC to 10 GHz
MS-162 Series
■Overview
Designed to be used as the interface antenna
connection for portable terminal devices as well
as circuit testing on microwave boards (DC to
10GHz) the coaxial switch offers high performace,
low loss, extremely high durability and reliability,
in a small and lightweight package.
Normally closed, the circuit is re-directed to the
plug side by the mating of the plug with the
receptacle.
■Features
Comparison with the existing MS-147
1. Low insertion loss
0.08 dB typical at 1 GHz
0.12 dB typical at 2 GHz
(not mated with the plug)
MS-147
MS-162
■Footprint
39.6mm2
2. Space-saving design
3.5 mm x 3.1 mm occupied board space.
14.0mm2
6.0
4.0
5.4
3.5
3. Low profile
3.5
3.1
5.8
6.6
2.5 mm max. protrusion above the board.
4. Lightweight
0.044 g total weight
5. Durability
12, 000 mating/unmating cycles, with corresponding plug.
MAX
2.5
MS-162 (Receptacle) contact has nickel plating areas to
prevent solder wicking into critical areas.
■Height
3.9
6. Critical area protection
65% saving of space
7. Board placement with automatic equipment.
Packaged on tape-and-reel.
36% lower profile
8. Self alignment
When mating, plug and receptacle will self align in
horizontal axis within 0.5mm.
■Weight
0.11g
9. RoHS compliant
0.044g
60% lighter weight
All components and materials comply with the
requirements of the EU Directive 2002/95/EC.
●Plugs
●SMA conversion adapter
■Applications
*Wireless communication modules (Bluetooth, WLAN,
UWB, ZigBee)
*Portable terminals, notebook computers, ETC, POS
terminals, GPS terminals, PDA, and any small devices
requiring verification of antenna/circuit performance and
re-direction of the transmission.
MS-162-C(LP)-1
MS-162-HRMJ-1
2006.2
1
■Product Specifications
Not mated with the plug
Open (Mated with MS-162-HRMJ-1)
Operating temperature range
–40ç to +85ç
Rated power
4W
Frequency range
DC to 10GHz
V.S.W.R.
Insertion loss
Isolation loss
1.2 max.
(DC to 3GHz)
1.2 max.
(DC to 3GHz)
1.5 max.
1.7 max.
(3GHz to 6GHz)
(6GHz to 10GHz)
1.6 max.
1.7 max.
(3GHz to 6GHz)
(6GHz to 10GHz)
0.15 dBmax.
(DC to 2GHz)
0.2 dBmax.
(DC to 2GHz)
0.20 dBmax.
0.40 dBmax.
(2GHz to 3GHz)
(3GHz to 6GHz)
0.3 dBmax.
0.5 dBmax.
(2GHz to 3GHz)
(3GHz to 6GHz)
0.70 dBmax.
(6GHz to 10GHz)
0.7 dBmax.
(6GHz to 10GHz)
Item
100 mA
2. Insulation resistance
1000 Mø min.
100 V DC
3. Withstanding voltage
No flashover or insulation breakdown
100 V AC / 1 minute
No electrical discontinuity of 10 µs or more
Contact resistance: 100 mø max.
6. Humidity
Insulation resistance: 10 Mø min.
7. Thermal shock
(1GHz to 3GHz)
(3GHz to 6GHz)
12 dBmin.
(6GHz to 10GHz)
Conditions
100 mø max.
5. Shock
(DC to 1GHz)
20 dBmin.
14 dBmin.
Specification
1. Contact resistance
4. Vibration
25 dBmin.
Frequency: 10 to 55 Hz, single amplitude of 1.5 mm,
2 hours in each of the 3 axis.
Acceleration of 490 m/s2, 6 ms duration,
sine half-wave waveform, 3 cycles in each of the 3 axis.
96 hours at 40ç, RH of 90% to 95%
Temperature: –55ç / +5ç to +35ç / +85ç / +5ç to +35ç
Time:
30
5 max.
/ +30 / +5max. (Minutes)
100 cycles
8. Durability
(mating/un-mating, with
12, 000 cycles
corresponding plug)
■Materials
Part
2
Material
Finish
Remarks
Shell
Brass
Gold plated
Insulators
Polyamide
UL94V-0
Common terminal
Beryllium copper
Partially gold plated (Nickel barrier)
Antenna terminal
Phosphor bronze
BHigh Frequency Characteristics (Typical)
●NORMALLY CLOSED(N.C) ~ (Not mated with the plug)
[dB]
0.0
INSERTION LOSS
0.4
0.6
0.8
1.8
V.S.W.R.
INSERTION LOSS
0.2
1.6
1.4
V.S.W.R.
1.2
4
8
6
1.0
10
[GHz]
●OPEN(N.O) ~ (Mated with the plug)
[dB]
0.0
0.4
0.6
0.8
INSERTION LOSS
1.8
V.S.W.R.
INSERTION LOSS
0.2
1.6
1.4
V.S.W.R.
1.2
4
6
8
1.0
10
[GHz]
8
10 [GHz]
[dB]
ISOLATION
10
ISOLATION
30
40
4
6
3
■Receptacle
3.1
2.4
3.5
B
Ø2.8
2.48
1.88
1
0.61
0.3
Part Number
CL No.
Packaging
MS-162
358-0208-3
MS-162 (01)
358-0208-3-01
C
RoHS
3, 000 pieces/reel
YES
100 pieces/bag
G
G
A
0.4
BCircuit diagram
Not mated with the plug (N.C)
G
G
Mated with the plug (N.O)
G
G
A
A
B
C
B
C
G
G
G
G
MS-162 Plug
MS-162
MS-162 Plug
MS-162
BPCB mounting pattern and metal mask dimensions
Metal mask dimensions
2.4
0.6
3.5
2.8
0.5
0.62
area show the conductive pattern prohibited area.
4
0.65
0.5
0.62
0.65
0.8
3.5
2.8
0.65
0.6
0.65
4
4
2.4
■Plug
■SMA conversion adapter
CL No.
RoHS
Part Number
CL No.
RoHS
358-0222-4
YES
MS-162-HRMJ-1
358-0210-5
YES
Ø7
6.3
Part Number
MS-162-C(LP)-1
13.7
1/4-36UNS-2A
12
24.29
13.6
2.4
6.29
6
Ø1.8
10.2
Ø4
Ø4
Applicable cable: 1.5D-HQEW, 1.5D-QEW (Fujikura Ltd.)
BRecommended Temperature profile
Temperature (ç)
10 sec. max.
240
200
160
150
●Typical Solder Paste
q
Maximum temperature
: 240ç
w
Peak temperature
: 200ç to 235ç
e
Peak temperature time
: 10 sec. max.
r
200ç min.
: 50 sec. max.
t
150ç to 160ç
: 40 sec. min.
Metal mask thickness: 0.12mm
Reflow cycles: 2 cycles
100
40 sec. min.
Temperature (ç)
Time (sec.)
50 sec. max.
5 sec. max.
260
●Typical Lead-free Solder Paste
q
Maximum temperature
: 260ç
220
w
Peak temperature
: 240ç to 255ç
200
e
: 5 sec. max.
r
220ç min.
: 50 sec. to 80 sec.
t
180ç to 200ç
: 120 sec. max.
180
100
120 sec. max.
Time (sec.)
50 sec. to 80 sec.
5
BPackaging Specifications
● Reel dimensions
8
4
12.4
.5
Unreeling direction
Ø1
1.75
2
Ø1
3.25
BRecommended Nozzle Dimensions
Ø1
Ø1.5
Ø3
6
Ø80
Ø180
12
5.5
3
Unreeling direction
BExample of Application
Installed in portable devices
O-ring
Note 1: When mounting the MS-162-C(LP)-1 make sure that the
recommended self alignment distances and angle can be
maintained.
Note 2: When fully mated the spring force F must be 10N to 15N.
F
Installed in test fixture
Floating mounting plate (Plug side)
Retaining plate
Pressure plate moves vertically
Mounting screw
A
F
To measuring
instrument
View A
Tilt
prevention
Load
F
MS-162-C(LP)-1
Load
0.5min.
Clearance
Stop
MS-162-C(LP)-1
MS-162
Board
0.5min.
Clearance
Self-centering
Mounting screw
Cable termination
Retaining plate
The retaining plate cannot protrude
and interfere with the cable termination areas.
Note 1: When mounting the MS-162-C(LP)-1 make sure that the recommended self alignment distances and angle can be
maintained.
Axial misalignment distance
Allowable angular misalignment for mating
±2.5°
0.5mm
Plug
MS-162-C(LP)-1
Receptacle
7
BPrecautions
1. Do not use the washing process.
2. Do note use hand soldering for mounting of MS-162.
3. When using a heat gun, hot plate, or similar methods, limit the temperature to 260ç applied for
10 seconds max.
4. Consult Hirose if your application, installation methods or end-user environment are different
than the recommended.
5. Please refrain from using the product in environments specifically affected by dust, high
humidity, gases, very high temperatures and very low temperatures.
6. When used as an RF interface of a portable terminal, consider using a rubber cap or other
means of protection against intrusion of dust, dirt or other harmfull elements.
7. When using, assure that the plug is fully inserted to the surface (P), as shown.
P
8
5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN
PHONE: 81-3-3491-9741, FAX: 81-3-3493-2933
http://www.hirose.com
http://www.hirose-connectors.com
The contents of this catalog are current as of date of publication. Contents are subject to change without notice for the purpose of improvements.
