Crimp Type Straight Cable Termination for Flexible Cable
1. Identify connector parts. (2 piece parts)
2. Strip cable to dimensions shown. Do not nick braid
or center conductor. A wire stripper of correct size
is recommended for this step. Twist stranded center
conductor into tight bundle and tin. Slide crimp sleeve onto
cable as shown.
3. Flare braid and slide cable into body making certain that the
cable insulation is flush with bottom of connector.
4. Arrange braid uniformly around crimp stem. Slide crimp
sleeve over braid and crimp securely using recommended
crimp tool.
Cable Group
Part No.
“A”
Crimp Hex
RG-178/U, 196
142-0002-221/226
.259 (6.58)
.105 (2.67)
RG-316/U, 161, 174,
179, 187, 188
142-0003-201/206
142-0003-231/236
142-0003-241/246
.312 (7.92)
.259 (6.58)
.259 (6.58)
.128 (3.25)
.128 (3.25)
.128 (3.25)
RG-316 DS, 188 DS
142-0004-201/206
142-0004-211/216
142-0004-221/226
.312 (7.92)
.259 (6.58)
.259 (6.58)
.151 (3.83)
.151 (3.83)
.151 (3.83)
Crimp Type Right Angle Cable Termination for Flexible Cable
2. Strip cable to dimensions shown. Do not nick braid or center
conductor. A wire stripper of correct size is recommended for
this step. Twist stranded center conductor into tight bundle and
tin. Slide crimp sleeve onto cable as shown.
cable insulation is flush with bottom of connector body.
4. Arrange braid uniformly around crimp stem. Slide crimp sleeve
over braid and crimp securely using recommended crimp tool.
Cable Group
Part No.
Crimp Hex
RG-316/U, 161, 174, 179, 187, 188
142-0003-301/306
.128 (3.25)
RG-316 DS, 188 DS
142-0004-301/306
.151 (3.83)
272
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0003-246”相匹配的价格&库存,您可以联系我们找货
