High Definition BNC Connectors
____________________________
The Shadow ™ in the trade name for the best high definition BNC connector available at any price Shadow™
BNC connectors fit all standard broadcast cables and utilize most standard existing tooling. These connectors
are made from precision machined brass. Insulator material is high density TFE to maintain a perfect dielectric
constant. Bomar connectors utilize a .042 diameter gold plated contact pin to maintain the best return loss in
high definition applications.
The Shadow™ is precision machined (not diecast) from brass. A special black nickel plating is
applied for a beautiful finish that is easily
identifiable as a high definition connector. Each
connector is precision matched to a specific
cable type.
Uses standard commercial tooling.
Part Number
Cable
HBC1505A
1505A
.255/.042* BDHD100
HBC1694A
1694A
.324/.042* BDHD100
HBC1694AX
1694A
.278/.042* BDHD100
HBC1855A
1855A
.178/.042* BDHD200
HBC179DT
179DT
.213
ferrule only*
BD17900
12
Point
Tool
.042 (pin
only)
* We recommend 12 point tool
Hex Crimp
for .042 pin
Tool
BDHD200
Bomar BD17900 (See
Below)
Other cable sizes are available by special order.
s
BD17900 crimp tool for all HD (.042 pin)
In an independent test The Shadow™ proved to have
the best return loss results at 3GHz.
Freq in GHz
Return Loss
(No Cable)
Return Loss
(No Cable)
Return Loss
(No Cable)
xxx
2.0
Bomar
- 29.4 dB
K-Brand
- 22.6 dB
A-Brand
- 23.3 dB
Return Loss
(No Cable)
AM-Brand
- 44.8 dB
Return Loss
(No Cable)
T-Brand
- 21.4 dB
2.6
- 26.6 dB
- 20.3 dB
- 20.9 dB
- 22.3 dB
- 20.2 dB
3.0
- 23.1 dB
- 18.0 dB
- 17.4 dB
- 20.0 dB
- 19.0 dB
Bomar P/N HBC1694A HP8648C, Slotted Line (Connector Only Used For True Results.)
Once cable is applied . .
back to index
2
很抱歉,暂时无法提供与“HBC1505A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+64.35478500+8.34161
