CONREVSMA007-R178
CONREVSMA007-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA007-R178 数据手册
Description Body Socket Insulation Spacer Gasket Support Heat Shrink Material Brass BE CU PTFE PTFE SI Rubber BE CU Polyolefin Finish Nickel Gold N/A N/A Rubber Gold Black REVISIONS 0.118 [3.00] 0.197 [5.00] REV RG-178 Cable DESCRIPTION DATE APPV B Updated footprint and dimensions; Added new title block 2-JUL-12 SAH C Updated stripping dimensions; Added dimensions to spacer and support 12-Jun-13 SAH 0.213 [5.40] RECOMMENDED CABLE STRIPPING DIMENSIONS 0.043 [1.10] PIN CHUCK H0.315 [8.00] 0.2x2x2 GROOVE Ø0.106 [2.70] 1/4-36UNS-2B THREADS 0.240 [6.10] 0.197 [5.00] 0.232 [5.90] Ø0.049 [1.25] SPACER SUPPORT SOCKET Ø0.118 [3.00] 0.591 [15.00] SIDE VIEW 0.787 [20.00] HEAT SHRINK NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. CONREVSMA007-R178 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. 7. 8. Strip cable to recommended dimensions. Slip heat shink and crimp ring onto cable. Solder support onto the braid. Place the spacer onto the center conductor. Solder or crimp the socket onto the center conductor. Insert the socket, center conductor, spacer and support into the body until the top of the socket is even with the white insulation in the body. Crimp the tail of the body onto the support with a 0.093” hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: B.MURPHY DT: 2-JUL-12 ENGR: S.HOGAN DT: 2-JUL-12 TITLE: 159 ORT LANE MERLIN, OR 97532 RP-SMA MALE CABLE END CRIMP FOR RG-178 CABLE SIZE DWG. NO. REV CONREVSMA007-R178 C SCALE: 2:1 DO NOT SCALE DRAWING SHEET 1 OF 1 LDCFDLT_A
CONREVSMA007-R178 价格&库存
很抱歉,暂时无法提供与“CONREVSMA007-R178”相匹配的价格&库存,您可以联系我们找货
