564A595M
564A595M
    WINCHESTER(温彻斯特)
    TNC PC MOUNT ALL METAL
564A595M 数据手册
- Page 11 - Specifications for TNC Connectors TNC Series connectors are miniature sized, and weatherproof and are electrically similar to BNC Series, except that they have a coupling method which utilizes a screw system giving them additional resistance against shock and vibration. They are especially designed for use from DC to 18 GHz, in vibration exposed equipment like in commercial and military radio telecommunications systems and avionics equipment. These connectors are particularly useful for applications in computer and medical equipment and test instrumentation. TNC Series have a constant impedance of 50 ohms and are available in a variety of cable configurations. MATERIALS Connector Parts Material Equivalent Standard † Connector Body and Parts Brass ISOCuZn38Pb2 Body Part Male Contact Pin Commercial Grade Brass Zinc Alloy/Brass QQ-B-626 Outer Contact Brass QQ-B-750 Socket Contact Socket Contact Beryllium Copper Phosphor Bronze QQ-C-530/MIL-H-7199 CuBe2 Crimp Ferrule Insulators, Standard Versions Annealed Copper Teflon QQ-C-576 L-P403/BS4271 Insulators, Standard Versions Rubber Gaskets Delrin Silicone Rubber Grade B ASTM-E1418PSI Plating Nickel (Silver Optional) MIL-G-45204 ------ ELECTRICAL Requirement Test † Specification Performance 50  Impedance ----- 75 Frequency Range VSWR RF Insertion Loss RF Leakage 0-18 GHz 0-1 GHz 1.30 Max. 0.2 dB Max. at 3 GHz -60 dB Min. at 3 GHz ----MIL- C-39012 MIL- C-39012 MIL- C-39012 Test Voltage (At Sea Level) 1500V rms MIL-STD-202 500V rms MIL-STD-202 5000 Megohms Min. MIL-STD-202 Working Voltage (At Sea level) Insulation Resistance Contact Resistance *Center Contact *Outer Contact 5mW Maximum 2mW Maximum MIL-C-39012 MECHANICAL & ENVIRONMENTAL Requirement Performance Test † Specification Durability 500 Insertions & Extractions Min. MIL-C-39012 Shock 50 G MIL-STD-202 Vibration 20 G from 80-2000 Hz MIL-STD-202 Cable Retention (Cable Types) 60 lbs. Minimum Pull Test MIL-C-39012 Coupling Nut 60 lbs. Maximum MIL-C-39012 Temperature Range Teflon: -55 to +199 C Delrin: -40 to +85 C Moisture Resistance Continuous Test -------MIL-STD-202 Salt Spray 48 Hours MIL-STD-202 †Products are made to conform to the Mil standard but are for commercial applications and not QPL ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 11 - Page 11 - Page 12 - 3 Piece Crimp TNC three piece crimp connectors feature the same semi-captive contacts as the BNC which “click” into place assuring perfect installation. Each crimp pin has a vent hole for optional soldering. Soldering is recommended for all stranded conductors 26 AWG or smaller. RG/U Cable Fig. No. 510A205F 510A204G 58A/U, 58C/U, Stranded, 141/U 59/U, 62/U, 210/U 57 57 510A204FV 58A/U, 58C/U, 141/U Plenum 58 Part Number RoHS compliant DRAWING REQUEST QUOTE Fig. 57 REQUEST Fig. 58 s Standard Clamp and Taper Grip TNC standard clamp style is a simplified version of the original military style. It is required that the contact be soldered to the center conductor of the cable. The Taper Grip style connectors require little cable preparation. Strip off all but a length of center conductor, push the taper under the cable’s shield, solder the contact, and assemble. Part Number Fig. 51 Fig.50 RG/U Cable 510A104F 58A/U, 58C/U, Stranded, 141/U 510A104G 510A304F 59/U, 62/U, 210/U 58A/U, 58C/U, Stranded, 141/U 510A304G 59/U, 62/U, 210/U RoHS compliant DRAWING REQUEST QUOTE REQUES Twist-On TNC Twist-On connectors are field installable and require no tooling other than a stripping tool for the cable preparation. The center conductor is inserted into Bomar’s unique Posi-Con™ contact, as the connector twists firmly onto the cable’s outer jacket. Part Number Gender RG/U Cable Fig. No. 510A405F Male 510A405G Male 520A405F Female 520A405G Female RoHS compliant 58A/U, 58C/U, Stranded, 141/U 59/U, 62/U, 210/U 53 53 58A/U, 58C/U, Stranded, 141/U 59/U, 62/U, 210/U REQUEST QUOTE 52 Fig. 53 52 Fig. 52 REQUEST DRAWING s Bulkhead Jacks Versions are available for front mounting (F/M), rear mounting (R/M) , crimp types, bulkhead mount grounded, or bulkhead mount isolated. These jacks are held into the panel by a hex-nut and lock washer. All units feature nickel plated, brass bodies, and gold plated phosphor bronze contacts. Part Number 521A245F 521A245G 526A515 526R515 Fig. 54 Fig. No. RG/U Cable 58A/U, 58C/U, Stranded, 141/U RG59/U, RG62/U, RG210 56 56 Any Cable Size Non Isolated Any Cable Size Isolated RoHS compliant REQUEST QUOTE DRAWING 54 55 REQUEST s Fig. 56 s Fig. 55 s s ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 12 - Page 12 - Page 13 - TNC Connectors Adapters These sturdy within-series TNC adapters are available in all standard designs. All connector bodies are plated with bright nickel. Male contacts are brass, female contacts are phosphor bronze. All contacts are plated with 5 micro-inches of gold. Part Number Fig. No. Description 532A505 Female/Female Inline Splice 60 535A544 535R544 543A505 Female/Female Bulkhead Inline Female/Female Bulkhead Inline, Isolated Female/Male/Female “T” Adapter 61 61 62 545A505 Female/Female/Female “T” Adapter 63 551A505 Female/Male Right Angle" 64 RoHS compliant DRAWING REQUEST QUOTE Fig. 62 REQUEST Fig. 63 Fig. 60 Fig. 64 Fig. 61 PC Board Jacks These TNC jacks are manufactured to the highest standards to assure stability in maintaining impedance matching at rated frequencies. Applications are in cellular communications, broadcast, and computer data. Contacts are phosphor bronze and will remain resilient even after 500 insertions. Part Number Body Material Description Contact Plating Fig. No. 561V504E Metal V-Bite W/ Teflon Reflow Solder Gold  564A595 White Valox Standard Profile W/ Posts Gold 66 564A595B 564A595BL BlackValox White Valox Standard Profile W/ Posts Low Profile W/ Posts Gold Gold 67 68 564A595BLB BlackValox Low Profile W/ Posts Gold 69 564A595M 564S595 Metal White Valox Standard Profile W/ Posts Vertical Mounting Gold Gold 70 71 564S595B 564S595M BlackValox Metal Vertical Mounting Vertical Mounting Gold Gold 72 73 RoHS compliant reflow or wave solder REQUEST QUOTE Fig. 71 Fig. 72 Fig. 73 RoHS compliant wave solder only REQUEST DRAWING Fig. 66 Fig. 68 Fig. 69 Fig. 70 ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 - Page 13 - Back to Index 13
564A595M 价格&库存
很抱歉,暂时无法提供与“564A595M”相匹配的价格&库存,您可以联系我们找货
