SBC8281(U)
SBC8281(U)
    WINCHESTER(温彻斯特)
    BNC BROADCAST GRADE BELDEN 8281
SBC8281(U) 数据手册
Specifications for BNC Connectors BNC style connectors are miniature, light-weight, weatherproof interconnecting devices characterized by their two-stud, quick disconnect bayonet lock coupling arrangement. Their design functions satisfactorily from DC to 11 GHz in static applications, or from DC to 4GHz in applications involving vibration. The connectors typically yield a low VSWR (reflected signal) to 4GHz. Primary applications include radio telecommunications, broadcast equipment, medical equipment, computer, Precision Video, High definition studio broadcast, video switching and test instrumentation where frequent coupling and de-coupling are necessary. Bomar’s BNCs are available in an extensive variety of configurations and cable sizes and are impedance matched to either 50 ohm or 75 ohm. MATERIALS Connector Parts Connector Body and Parts Male Contact Pin Commercial Grade Outer Contact Socket Contact ---------Crimp Ferrule Insulators, Standard Versions ---------Rubber Gaskets Plating Material Brass Brass Zinc Alloy/Brass Brass Beryllium Copper Phosphor Copper Annealed Copper Teflon Delrin Silicone Rubber Nickel (Silver Optional) Equivalent Standard ISOCuZn38Pb2 Body Part QQ-B-626 -------------QQ-B-750 QQ-C-530 / MIL-H-7199 CuBe2 QQ-C-576 L-P403 / BS4271 Grade B ASTM-E1418PSI MIL-G-45204 ELECTRICAL Requirement Performance Impedance Frequency Range VSWR RF Insertion Loss RF Leakage Test Voltage ( At Sea Level) Working Voltage ( At Sea Level ) Insulation Resistance Contact Resistance 50 75 0-4GHz 0-1 GHz 1.30 Max. 0.2 db Min. at 3 GHz -55 db Min. at 3 GHz 1500V rms 500V rms 5000 Meg ohms Min. 3 Milli ohms Max. Test † Specification -----------MIL-C-39012 MIL-C-39012 MIL-C-39012 MIL-STD-202 MIL-STD-202 MIL-STD-202 MIL-C-39012 MECHANICAL & ENVIRONMENTAL Requirement Performance 500 Insertions & Extractions Min. 50 G 20 G from 80-2000 Hz 60 lbs. Minimum Pull Test 60 lbs. Maximum Teflon: -55 to +199 C Delrin: -40 to +85 C Continuous Test 48 Hours Durability Shock Vibration Cable Retention (Cable Types) Coupling Nut Temperature Range Moisture Resistance Salt Spray Test † Specification MIL-C-39012 MIL-STD-202 MIL-STD-202 MIL-C-39012 MIL-C-39012 ----------------------MIL-STD-202 MIL-STD-202 †Products are made to conform to the Mil standard but are for commercial applications and are not QPL FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 -Page1-Page2- BNC 3 Piece Crimp Back to Index 1 BNC three piece crimp connectors feature semi-captive contacts that “click” into place assuring perfect installation. Each crimp pin has a vent hole for optional soldering. Soldering is recommended for all stranded conductors 26 AWG or smaller. Part Number (Male) 310A205A 310A205A18 310A205F 310A205FS 310A205FV 310A205FV2 310A205FV3 310A204G 310A205G20 310A205G23 310A205MV 310B205MV 310A205N 310A205P 310B205Q 310A204T 310A208W2 RoHS compliant (I.D.) Fig. No. ** .200 In. Fig. 1 .200 In. Fig. 1 .124 In. Fig. 1 .124 In. Fig. 1 .125 In. Fig. 2 .125 In. Fig. 2 6, 21 AWG Center Conductor 6 CATV, 18 AWG Center Conductor 58A/U, 58C/U Stranded, 141, Thin PVC 58/U Solid Conductor 58/U Thin-Net Plenum Mini 59, RGB Cable (23 AWG) .125 In. Mini 59, RGB Cable (26 AWG) Fig. 2 .150 In. Fig. 1 .150 In. Fig. 1 .150 In. Fig. 1 .125 In. Fig. 3 .125 In. Fig. 3 .090 In. Fig. 3 .125 In. Fig. 1 .205 In. Fig. 1 .150 In. Fig. 2 .103 In. Fig.1 ** crimp shank RG/U Cable 59, 62, 210 RG59 20 AWG Center Cond. Belden 8241 174, 178, 196, Mini RGB Cable 50  174, 178, 196, Mini RGB Cable 75  179, 187 223 Belden 8281 True 75 Ohms 59, 62, Plenum Mini 59, RGB Cable (26 AWG) REQUEST QUOTE Fig.1 Fig.2 Fig.3 Click Here for Connector Dimensions/Stripping Dimensions REQUEST DRAWING BNC Twist-On and 2 Piece Crimp BNC Twist-On connectors are field installable and require no tooling other than a stripping tool for the cable preparation. The center conductor is inserted into Bomar’s unique Posi-Con ™contact, as the connector is twisted onto the cable’s outer jacket. BNC 2 Piece crimp connectors make use of a fully captivated pin. Just insert the center conductor into the connector body, slide the ferrule over the braid, and apply a single hex-crimp to the ferrule. These connectors are easy to install and reliable and are recommended only for the lower data transmission speeds. Part Number 310A405A 310A405F 310A405F1 310A405F2 310A405F3 310A405G 310A405T 320A405F 320A405G 310X205F 310X205G 320X205F 320X205G Gender Male Male Male Male Male Male Male Female Female Male Male Female Female RoHS compliant Fig. No. Fig. 8 Fig. 8 Fig. 8 Fig. 8 Fig. 8 Fig. 8 Fig. 8 6, Thick net 58A/U Solid Cond, 141, Thin PVC 58/U Solid Cond. -.172"- .178 “ 58/U Thin Plenum - .158" - .162" Thin Plenum .150" 59, 62, 210 PVC 59, 62, 210 Plenum Fig. 8A 58 Solid (PVC) Fig. 8A 59, 62, 210 (PVC) Fig. 6 Fig. 6 RG58 (PVC) RG59, 62 (PVC) Fig. 7 RG58 (PVC) Fig. 7 RG59, 62 (PVC) RG/U Cable REQUEST QUOTE Fig.8 Fig.8A Fig.6 Fig.7 s s REQUEST DRAWING FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Back to Index 2 -Page 2- Page 3 - BNC Connectors BNC Standard Clamp BNC standard clamp style is a simplified version of the original military clamp style. It is required that the contact be soldered to the center conductor of the cable. Part Number 310A105A Gender Fig. No. RG/U Cable Male 9 6 310A105D Male 9 11A 310A105F Male 9 58, 58A, 58C, 141 310A105G Male 9 59, 62, 210 310A105M Male 9 174, 188, 316 320A105F* Female N/S 58, 58A, 58C, 141 320A105G* Female N/S 59, 62, 214 RoHS compliant REQUEST QUOTE Figure 9 REQUEST DRAWING BNC Specialty Broadcast Plugs Click here for complete Broadcast Catalog Broadcast grade BNC connectors are perfectly matched to 75 ohm impedance’s. The superior plugs are for studio wiring and other broadcast uses. Solid precision machined brass, not die-cast, hold up under the toughest conditions. Here, we are showing the eight most popular but there are many more versions matched to the popular cable manufacturer’s part number. Gender Belden Cable SBC1505A SBC1694A Part Number Male Male 1505A 1694A SBC1695A SBC1855A SBC7731A SBC8218 Male Male Male Male 1695A 1855A 7731A 8218 SBC8241 SBC8281 Male Male 8241 8281 s s s s RoHS compliant REQUEST QUOTE s REQUEST DRAWING BNC Bulkhead Jacks Versions are available for front mounting, (F/M) rear mounting, (R/M) crimp types, bulkhead mount grounded, or bulkhead mount, isolated. (Colorcoded available.) These jacks are held into the panel by a hex-nut and lock washer. All units feature nickel plated, brass bodies, and gold phosphorbronze contacts R/M Crimp, RG6 Fig Hole Dwg No. ID 13 .500 321A245F R/M Crimp, RG58 , Thin-net PVC 13 .500 321A245FV R/M Crimp, Thin-Net Plenum 13 .500 321A245G R/M Crimp, RG59, 62, 210 13 .500 321A245M R/M Crimp, RG174, 188, 196, 316 13 .500 321B245M* R/M Crimp, RG174, 188, 196, 316 13 .500 321B245N* R/M Crimp, RG179, 187 N/S .500 326A515 F/M Solder (Grounded) 14 .375 326R515 F/M Solder (Isolated) White Bushing 15 .375 326R515RD F/M Solder (Isolated) Red Bushing 16 .375 326R515GN F/M Solder (Isolated) Green Bushing 16 .375 326R515BL F/M Solder (Isolated) Blue Bushing 16 .375 Part Number 321A245A Figure 13 Figure 15 Figure 14 Figure 16 Description s s s s RoHS compliant REQUEST QUOTE REQUEST DRAWING FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 3 Back to Index - Page 4 - BNC Panel Jacks and Plugs BNC panel plugs and jacks are of machined brass construction for maximum reliability and quality. All contacts are plated with a minimum of five micro-inches of gold. The square panel types mount on .500 inch centers. The bulkhead type mounts into a .380 “D” shaped panel hole. All connector bodies are bright-nickel plated. Part Number Description Notations Fig. No. Dwg. 316A524C Male Bulkhead Panel Mount .380" Mtg. Hole 317A507 Male Panel Mount . 500 Mtg. Hole Centers 20 321A205F Female Panel Mount, Crimp Fits RG58/U Cables 21 321A205G Female Panel Mount, Crimp Fits RG59, 62 , 210 21 321A205M Female Panel Mount, Crimp Fits RG174, 178, 196 21 327A507 Female Panel Mount, Solder .500 Mtg. Hole Centers 22 RoHS compliant REQUEST QUOTE 19 --------- Figure 19 Figure 20 Figure 21 Figure 22 REQUEST DRAWING BNC PC Board Vertical Jacks BNC vertical mount jacks are available in straight PC mounts and “through-panel” styles. The “through-panel”, 364 Series, is made in both isolated and grounded versions and are ideal for applications where multiple insertions will require a connector which can endure the stress of higher torque. Part Number 361A514* 361A505* Body Plating or Description Material Nickel / Brass Straight PC Mount 50 Nickel / Brass Straight PC Mount 50  361A534* Nickel / Brass 3 Post PC Mount 50  Delrin Gold .788 27A Nickel/Zinc 4 Post W/ Press Fit Center Pin 50 Delrin Gold .925 27B Nickel/Zinc 4 Post W/ Press Fit Center Pin 75 Delrin Gold .925 27B White Valox PC Mount, Thru-Panel, 50  Delrin Gold 1.36 23 364S595B Black Valox PC Mount, Thru-Panel, 50  Delrin Gold 1.36 24 364S595M Nickel/Zinc PC Mount, Thru-Panel, 50  Delrin Gold 1.36 25 364S795* White Valox PC Mount, Thru-Panel, 75 Delrin Gold 1.36 23 364S795B* Black Valox PC Mount, Thru-Panel, 75  Delrin Gold 1.36 24 364S795M* Nickel/Zinc PC Mount, Thru-Panel, 75  Delrin Gold 1.3 25 361A505APF 361A705APF 364S595 RoHS compliant reflow or wave solder RoHS compliant wave solder only Insul. Mat. Teflon Delrin REQUEST QUOTE Con. "L" Dim Plating Gold .717 Gold .914 Fig. No. 26 27 Dwg. ----- Fig. 23 REQUEST DRAWING Fig. 24 Fig. 25 s s s s Fig. 26 The press-fit center pin locks the connector into the PC board so it is held firmly for reflow or wave soldering. Fig. 27B * Denotes that items are not popular and may require a special minimum quantity requirement. Fig. 27A ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 4 Back to Index - Page 4 - Page 5 - BNC Connectors BNC PC Board Right Angle JacksX These BNC jacks are manufactured to the highest standards to assure stability in maintaining impedance matching at 50 ohm and 75 ohm applications. The 50 ohm versions have been approved by most of the U.S. manufacturers of LAN cards, and the 75 ohm is in wide use in High Definition Video applications which require the use of a True 75 ohm connector. Contacts are phosphor bronze and will remain resilient even after hundreds of insertions. Part Number Fig 28 ig. Fig. 30 Fig. 32 Fig. 34 Fig 29 Fig. 31 Fig. 33 Fig. 35 Body Material Description Imp. Height Contact Fig. Dwg. F.M.S. Plating No. 364M095 Nickel/Zinc 4 Post Low Profile, Metal 50 .453 Gold 38 364M0975 Nickel /Zinc 4 Post Low Profile, Metal 75 .453 Gold 38 364A595 White Valox Standard Profile W/ Posts 50 .610 Gold 28 364A595T White Valox Standard Profile W/ Posts (TPX) 50 .610 Gold 28 364A595NP* White Valox Standard Profile WO Posts 50 .610 Gold 35 364A595NPT* White Valox Standard Profile WO Posts (TPX) 50 .610 Gold 35 364A595B Black Valox Standard Profile W/ Posts 50 .610 Gold 30 364A595BT Black Valox Standard Profile W/ Posts (TPX) 50 .610 Gold 30 364A595BNP* Black Valox Standard Profile WO Posts 50 .610 Gold 35 364A595BNPT* Black Valox Standard Profile WO Posts (TPX) 50 .610 Gold 35 364A595BL White Valox Lo Profile W/ Posts 50 .515 Gold 29 364A595BLT White Valox Lo Profile W/ Posts (TPX) 50 .515 Gold 29 364A595BLNP* White Valox Lo-Profile W/O Posts 50 .515 Gold 34 364A595BLB Black Valox Lo-Profile W/ Posts 50 .515 Gold 31 364A595BLBT Black Valox Lo-Profile W/ Posts (TPX) 50 .515 Gold 31 364A595BLBNP* Black Valox Lo-Profile W/O Posts 50 .515 Gold 34 364M595 Nickel /Zinc Standard Profile W/ Posts 50 .620 Gold 32 364M595T Nickel /Zinc Standard Profile W/ Posts (TPX) 50 .620 Gold 32 364M595M Nickel /Zinc Super Lo-Profile W/ Clips 50 .340 Gold 35A 364M595MT Nickel /Zinc Super Lo-Profile W/ Clips (TPX) 50 .340 Gold 35A 364M595L Nickel / Zinc Lo-Profile W/ Posts 50 .529 Gold 33 364M595LT Nickel / Zinc Lo-Profile W/ Posts (TPX) 50 .529 Gold 33 364A795 White Valox Standard Profile W/ Posts (TPX) 75 .610 Gold 28 364A795T White Valox Standard Profile W/ Posts 75 .610 Gold 28 364A795B Black Valox Standard Profile W/ Posts 75 .610 Gold 30 Fig. 36 (top) Fig. 37 RoHS compliant reflow or wave solder only RoHS compliant wave solder REQUEST DRAWING REQUEST QUOTE 364A795BT Black Valox Standard Profile W/ Posts (TPX) 75 .610 Gold 30 364A795BL White Valox Lo-Profile W/ Posts 75 .515 Gold 29 364A795BLT White Valox Lo-Profile W/ Posts (TPX) 75 .515 Gold 29 364A795BLB Black Valox Lo-Profile W/ Posts 75 .515 Gold 31 364A795BLBT Black Valox Lo-Profile W/ Posts (TPX) 75 .515 Gold 31 364M795 Metal Standard Profile W/ Posts 75 .620 Gold 32 364M795T Metal Standard Profile W/ Posts (TPX) 75 .620 Gold 32 364M795L Metal Lo-Profile W/ Posts 75 .529 Gold 33 364M795LT Metal Lo-Profile W/ Posts (TPX) 75 .529 Gold 33 364F595BL 364F595BLB 364H595BL 364H595BLB White Valox Black Valox White Valox Black Valox 9400pF 500V Decoupled 9400 pF 500V Decoupled 9400 pF 1500V Decoupled 9400 pF 1500V Decoupled 50 50 50 50 .515 .515 .515 .515 Gold Gold Gold Gold 36 37 36 37 364NT Zinc/Brass Jam Nut ( 364 Series) N/A ---- ---- 36N 364LW Zinc/ Steel Lock Washer ( 364Series) N/A ---- ---- 37N 364 KNT Brass/Nickel Knurled Nut (364 Series) N/A ---- ---- 38N (TPX) insulator for re-flow solder Board Clips Are Available In Place of Posts. Add Suffix “C” Spear-point clips lock snuggly into the board. Hardware Fig. 36N Fig. 37N Note: Mounting hardware is optional and must be ordered separately. Hardware is not sold without the connectors. Fig. 38N * Denotes that items are not popular and may require a special minimum order quantity. REQUEST QUOTE REQUEST DRAWING _____________________________ --------- FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 5 - Page 5 - Page 6 - BNC V-Bite ® PC Edge Mount The V-Bite ® is an industry award winning design PCB connector with all the advantages a designer could want. It edge mounts to the board which offers the lowest profile and utilizes very little PCB real estate. It lends itself to surface mount and through-hole soldering techniques. There are versions for IR and convection reflow soldering. Because the connector locks into place both above and below the PCB it disperses rotational torque relief to the board and not the solder points. The V-Bite ® design offers the lowest VSWR ratings due to the straight through-put contact design. No right angles for reflection. Available in 50 and 75 ohm, threaded and non-threaded. Other options for PCB thickness available. Other interfaces available. ( See “F”, BNC Twin and TNC sections.) Part Number 361V504ER 361V504ET 361V504EFT Description Imp BNC Jack W/ Teflon For Reflow Solder 50 BNC Threaded Jack W/ Teflon For Reflow 50 Solder BNC Threaded Jack W/ Teflon Insulator/Flange 50 Fig. No. Contact Brass./Gold 39A Brass./Gold 39 Brass./Gold 39B 361V509E BNC Jack W/ Polyethylene Insulator 50 Brass/Tin 39A 361V509ET BNC Threaded Jack W/ Polyethylene Insulator 50 Brass/Tin 39 75 Brass./Gold 39A 75 Brass./Gold 39 361V704ER 361V704ET 361V704EFT 361V709E 361V709ET BNC Jack W/ Teflon For Reflow Solder BNC Threaded Jack W/ Teflon For Reflow Solder BNC Threaded Jack W/ Teflon Insulator/Flange 75 Brass./Gold 39B BNC Jack W/ Polyethylene Insulator BNC Threaded Jack W/ Polyethylene Insulator Brass/Gold 39A Brass./Gold 39 Brass./Gold 39C 361KNT Knurled Nut (361 Series) 75 75 NA 3M61V704 Mini- BNC Jack W/ Teflon for Reflow Solder 75 RoHS compliant reflow or wave solder RoHS compliant wave solder only Dwg. --- REQUEST QUOTE --- ----- --- REQUEST DRAWING Low Profile .270 High FMS Anti Rotational VSWR 1.15:1 Patented V-Bite® Snaps Into PCB Surface Mount Center Contact Pick & Place Version Available Fig. 39 Fig.39A Fig.39B Fig. 39C s s BNC Reduced Size PCB Right Angle Mount The Super Low™ Profile BNC PC jack reduces the amount of board space needed to mount a PC jack. Board clips hold the unit in place for soldering. The smallest, lowest profile right angle BNC jack available. The Lo-Deco™ features a four post design that offers greater stability after wave soldering. Also featured is a gold plated contact and nickel plated cast zinc body. Smooth, sleek and aesthetically pleasing design is tumbled to remove casting lines. Part Number Description Imp. Contact Fig. No. 364M595M BNC Super Low Profile Jack 50 Phos./Gold 35A 364M595MT BNC Super Low Profile Jack 50 Phos./Gold 35A 364M795M BNC Super Low Profile Jack 75 Phos./Gold 35A 364M795MT BNC Super Low Profile Jack 75 Phos./Gold 35A Dwg. 364M095 BNC Lo-Deco Jack 50 Phos./Gold 38 364M0975 BNC Lo-Deco Jack 75 Phos./Gold 38 RoHS compliant reflow or wave solder QUOTE RoHS compliant wave solder only REQUEST DRAWING REQUEST . Fig 35A PC Layout for Super Low Profile Fig. 38 *Denotes that items are not popular and may require a special minimum order quantity. ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 6 Back to Index - Page 6 - Page 7 - BNC Connectors BNC Dual PC Jacks (Threaded) Right Angle or Vertical Stacked: When board space becomes a serious issue and you still need the robust, full size, BNC connectors, a dual stacked right angle or vertical version will do the trick. Assembly insertion time is cut in half as well. The Dual 364 series is available in both Valox isolated and all metal construction. (shown with closed back option FS) Right Angle Part Number Fig. 38A Fig. 38B Description Imp. Contact Fig.No. Dwg. 364A2595 Dual Right Angle, White Valox  Phos./Gold 38A 364A2595T Dual Right Angle, White Valox (TPX)  Phos./Gold 38A 364A2795 Dual Right Angle, White Valox  Phos./Gold 38A 364A2795T Dual Right Angle, White Valox (TPX)  Phos./Gold 38A 364A2595B Dual Right Angle, Black Valox  Phos./Gold 38A 364A2795B Dual Right Angle, Black Valox  Phos./Gold 38A 364M2595 Dual Right Angle, Metal  Phos./Gold 38B 364M2595T Dual Right Angle, Metal (TPX)  Phos./Gold 38B 364M2795 Dual Right Angle, Metal  Phos./Gold 38B 364M2795T Dual Right Angle, Metal (TPX)  Phos./Gold 38B 3M64M2795 Dual Right Angle, Metal Mini-BNC 75 Phos-Gold 38C 364KNT Knurled Nut for Dual BNC N/A Brass/Nickel 38D Vertical Fig. 40D Fig. 38C Part Number Description Imp. Contact Fig.No. 364S2595 Dual Vertical, White Valox  Phos./Gold 40D 364S2795 Dual Vertical, White Valox  Phos./Gold 40D 364S2595B Dual Vertical, Black Valox  Phos./Gold 40D 364S2795B Dual Vertical, Black Valox  Phos./Gold 40D 364S2595M Dual Vertical, Metal  Phos./Gold ---- 364S2795M Dual Vertical, Metal  Phos./Gold ---- Tool Fig. 38D Fig. 38E Part Number BD36400 Description - Imp. Hex Shafted Tool for Knurled Nut Contact Fig.No. N/A Steel/Nickel 38E RoHS compliant reflow or wave solder RoHS compliant wave solder only QUOTE REQUEST DRAWING REQUEST Note:Hardware is optional and must be ordered separately BNC Multi-Port PC Jacks (Non-Threaded) Side By Side: These right angle units are available in dual or quad configurations. These units are not threaded for panel installation using a jam nut. Up one fourth the installation time. Part Number Imp. Contact Fig. No.  Phos./Gold 38B  Phos./Gold 38B  Phos./Gold 38B  Phos./Gold 38B  Phos./Gold NS  Phos./Gold. NS 365A4595B Quad Right Angle, Side By Side Black Valox  Phos./Gold NS 365A4795B Quad Right Angle, Side By Side Black Valox  Phos./Gold 365A2595 365A2795 365A2595B 365A2795B 365A4595 365A4795 Description Dual Right Angle, Side By Side White Valox Dual Right Angle, Side By Side White Valox Dual Right Angle, Side By Side Black Valox Dual Right Angle, Side By Side Black Valox Quad Right Angle, Side By Side White Valox Quad Right Angle, Side By Side White Valox RoHS compliant reflow or wave solder RoHS compliant wave solder only QUOTE REQUEST DRAWING NS REQUEST Fig.38B ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 - Page 7 - Page 8 - - Page 9 - BNC Adapters Back to Index 7 These sturdy within-series BNC adapters are available in all standard designs. Additionally, several unique constructions compliment the product group and allow adaptations for every conceivable application. All connector bodies are plated with bright nickel. Male contacts are brass, female contacts are phosphor bronze. All contacts are plated with 5 micro inches of gold. Part Number 330A505 332A505 335A544 335R544 343A205F 343A205G 343A505 345A505 351A505 383U505 383U205F 383U205G 383K505* 383P505* 353U205F* 353U205G* 353U505* 393U205F* 393U205G* 393U505* RoHS compliant Fig. No. Description Male/ Male Inline Barrel Splice Female/Female Inline Splice Female/Female Inline Bulkhead Mount (Grounded) Female/Female Inline Isolated Bulkhead (Metal Outer Thread) Crimp “T” Adapter for RG58 Cable Crimp “T” Adapter for RG59, 62 Cables Female/Male/Female “T” Adapter (Yes, it runs with Netware™ ) Female/Female/Female “T” Adapter Female/Male Right Angle Adapter The Goalie™ The Goalie Brute™ Crimp Version for RG58 Cable The Goalie Brute™ Crimp Version for RG59, 62 Cables The Goalie Brute™ The Insulated Goalie Male/Female/Female Right Angle Double-Down™Crimp for RG58 Male/Female/Female Right Angle Double-Down™ Type for RG59 Male/Female/Female Right Angle Double-Down™ Male/Female/Female Straight Double-Down™Crimp for RG58 Male/Female/Female Straight Double-Down™Crimp for RG59 Male/Female/Female Straight Double-Down™ REQUEST QUOTE REQUEST DRAWING 35 36 37 37 41 41 38 39 40 42 45 45 43 44 49 49 48 47 47 46 Fig. 39 Fig. 38 Fig. 40 Fig. 42 Fig.44 Fig. 43 Fig. 35 Fig. 36 Fig. 37 Fig. 41 Fig. 48 Fig. 49 Fig. 46 Fig. 45 Fig. 47 Specialty LAN Adapters Double Down™ adapters are designed to allow parallel cables entering a patch panel, or a BNC LAN terminal port to be guided at a right angle to the input jack. Two versions accomplish this: one is a right angle with side-by-side jacks for areas with little rear clearance, and the other is a straight version for installations where width between panel jacks in limited. Crimp types are for permanent installations. Goalie, and Goalie Brute allow parallel cable 90° entry which require a minimum of rotational cable space. *Minimum quantity Requirements May Apply - Contact Sales ________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 9 - Page 9 - Page 10 - BNC Connectors BNC Terminators BNC terminators are available in standard 1% tolerance versions and in the economy 5% tolerance styles. The standard types have removable color coded caps for easy identification. The economy type are color coded as well but caps are not removable. Part Number Description Fig. No. 50 310X054A 50  with Red Cap 310C054 50  with Grounding Chain 51 310X074 75  with Blue Cap 50 HBC310X075 75 Precision .1% Tolerance 52 310X094 93 with Yellow Cap 50 HBC310X075 75  Precision .1% Tolerance 53 EJ175 50  Economy N/S EJ177 75  Economy N/S EJ179 93  Economy N/S RoHS compliant REQUEST QUOTE Fig. 50 Fig. 51 REQUEST DRAWING Fig. 52 s s s ss FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index - Page 10 - Coax Crimp Tools Professional grade hex-crimp tools for coaxial connectors are available in ratchet and non-ratcheting types, both provide dependable service. Ratchet tools feature replaceable dies. Included is a convenient release mechanism to unlatch the ratchet in the event of an improper crimp. Each too also crimps the contact pin to the conductor. Part Number BD10100 BDHD100 BDHD200 BDHD100 BD11012 BDHD100 Description Hex Crimp Ratchet for "F" Types, RG59, RG6 Hex Crimp Ratchet for Belden 8281 Hex Crimp Ratchet for BNC/TNC RG58,59,62 and MV Hex Crimp Ratchet for Mini-RG59 Hex Crimp Ratchet for "N" Crimp RG11, RG213, RG214 Hex Crimp Ratchet for BNC/TNC RG6, RG59 REQUEST QUOTE - Page 11 - s 10
SBC8281(U)
物料型号: - 连接器零件和材料:包括黄铜、锌合金/黄铜、铍铜、磷青铜、退火铜、绝缘子材料等。 - 电镀:镍(可选银色)。
器件简介: - BNC连接器是一种小型、轻量级、防水的互连设备,具有双螺钉、快速断开的卡扣式锁定装置。 - 设计适用于从直流到11 GHz的静态应用,或在涉及振动的应用中从直流到4 GHz。
引脚分配: - 详细列出了不同型号的BNC连接器的零件编号、性别(公/母)、图号和适用的RG/U电缆类型。
参数特性: - 包括阻抗(50或75欧姆)、频率范围、VSWR、射频插入损耗、射频泄漏、测试电压、工作电压、绝缘电阻、接触电阻等。
功能详解: - 描述了BNC连接器的耐久性、冲击、振动、电缆保持力、耦合螺母、温度范围、耐湿性和盐雾测试等机械和环境性能。
应用信息: - 主要应用包括无线电通信、广播设备、医疗设备、计算机、精密视频、高清演播室广播、视频切换和测试仪器等。
封装信息: - 提供了BNC连接器的不同配置、电缆尺寸和阻抗匹配信息。
SBC8281(U) 价格&库存
很抱歉,暂时无法提供与“SBC8281(U)”相匹配的价格&库存,您可以联系我们找货
