142-0093-801
142-0093-801
    CINCH
142-0093-801 数据手册
Crimp Type Straight Cable Termination for End Launch 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin. Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable insulation is flush with bottom of connector body. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Cable Group Part No. Crimp Hex RG-178/U, 196 142-0002-811 .105 (2.67) RG-316/U, 161, 174, 179, 187, 188 142-0003-801 142-0003-811 .128 (3.25) .128 (3.25) RG-316 DS, 188 DS, 179 DS, 187 DS 142-0004-801 142-0004-811 .151 (3.84) .151 (3.84) RG-58/U, 141, 303 142-0007-801 142-0007-811 .213 (5.41) .213 (5.41) RG-142/U, 55, 223, 400 142-0008-801 142-0008-811 .213 (5.41) .213 (5.41) Solder Type Straight Cable Termination for End Launch 1. Identify connector parts. (1 piece part) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. 3. Insert cable into body making sure cable is bottomed against shoulder body. Solder body to cable. Use a minimum amount of heat to minimize cable dielectric movement. Cable Group Part No. RG-405/U (.086 Semi-Rigid) 142-0093-801/806 RG-402/U (.141 Semi-Rigid) 142-0094-801/806 .250 Semi-Rigid 142-0096-801/806 273 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0093-801 价格&库存
很抱歉,暂时无法提供与“142-0093-801”相匹配的价格&库存,您可以联系我们找货
