CONREVMCX005
CONREVMCX005
    LINXTECHNOLOGIES(灵思)
    RP-MCX
CONREVMCX005 数据手册
Description Body Pin Insulation Crimp Ring Washer Nut Heat Shrink Material Brass PH Bronze PTFE Brass Brass Brass Polyolefin Finish Gold Gold N/A Gold Gold Gold Black RECOMMENDED MOUNTING HOLE B APPV SAH Ø0.197 (5.00) Ø0.187 (4.75) CRIMP RING 0.787 (20.00) H0.250 (6.35) PIN Ø0.102 (2.60) 0.232 (5.90) 0.272 (6.90) Ø0.154 (3.90) Ø0.037 (0.95) 0.276 (7.00) CONREVMCX005 ASSEMBLY INSTRUCTIONS WASHER NUT 0.378 (9.60) 0.571 (14.50) 6. 7. 10-56 UNS-2B THREADS RECOMMENDED CABLE STRIPPING DIMENSIONS 0.197 (5.00) 1. 2. 3. 4. 5. Ø0.377 (9.57) H0.250 (6.35) 0.134 (3.40) DATE Added new title block and heat shrink; Updated instructions 11-JUL-12 FLAT 0.173 (4.40) FLAT 0.173 (4.40) 0.079 (2.00) DESCRIPTION HEAT SHRINK SIDE VIEW 10-56 UNS-2A THREADS REVISIONS REV RG-174 Cable 0.055 (1.40) 0.020 (0.50) Strip the cable to the recommended dimensions. Slip heat shrink and crimp ring over stripped cable Solder the pin to the center conductor. Insert the pin, center conductor, and insulator into the body until the pin snaps in. Wrap the braid around the tail of the body and crimp the ring with a 0.128” hex crimp tool(or one labeled for use with RG-174 cable). Use heat shrink to cover crimp. Use the nut and washer to secure the connector to a case. NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 159 ORT LANE MERLIN, OR 97532 TITLE: RP-MCX FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVMCX005 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVMCX005 价格&库存
很抱歉,暂时无法提供与“CONREVMCX005”相匹配的价格&库存,您可以联系我们找货
CONREVMCX005
    • 1+58.40640
    • 200+23.30640
    • 500+22.52880
    • 1000+22.14000
