CONREVSMA005-R178
CONREVSMA005-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA005-R178 数据手册
Description Body Pin Pin Insulator Washer Nut Spacer Shield Sleeve Retaining Nut Crimp Ring Heat Shrink Material Brass Brass PTFE Brass Brass PTFE Brass Brass Brass Polyolefin Finish Nickel Gold N/A Nickel Nickel N/A Nickel Nickel Nickel Black REVISIONS 0.189 [4.80] 0.213 [5.40] 0.197 [5.00] REV RG-178 Cable B DESCRIPTION Updated footprint and dimensions; Added new title block 0.446 [11.40] 0.020 [0.50] Ø0.179 [4.55] WASHER 0.234 [6.00] 0.118 [3.00] 0.917 [23.30] RETAINING NUT SPACER STRIPPED CABLE HEAT SHRINK NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 2. DIMENSIONS APPLY AFTER FINISHING. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONREVSMA005-R178 ASSEMBLY INSTRUCTIONS Strip cable to recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Insert the stripped cable through the retaining nut, shield sleeve, and spacer. Solder the pin to the center conductor. Insert the pin into the pin insulator, then screw the main body onto the retaining nut. Wrap the braid around the tail of the body and crimp the ring with a 0.100" hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. Use the nut and washer to secure the connector to a case. SPACER CRIMP RING SHIELD SLEEVE MAIN BODY RECOMMENDED MOUNTING HOLE 0.059 (1.50) PIN 7. 8. Ø0.254 [6.50] 0.094 [2.40] 0.010 [5.00] 0.636 [16.30] PIN INSULATOR 6. Ø0.049 [1.24] PIN WASHER 4. 5. HEAT SHRINK 0.441 [11.20] Ø0.079 [2.00] SIDE VIEW 1. 2. 3. Ø0.118 [3.00] CRIMP RING NUT NUT SAH Ø0.126 [3.20] H0.315 [8.00] 0.065 [1.65] 29-JUN-12 1/4-36UNS-2A THREADS Ø0.402 [10.20] 1/4-36UNS-2B THREADS APPV 0.787 [20.00] 0.236 [6.00] RECOMMENDED CABLE STRIPPING DIMENSIONS DATE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 RP-SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG178 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 29-JUN-12 ENGR: S.HOGAN DT: 29-JUN-12 SCALE: 2:1 REV CONREVSMA005-R178 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA005-R178
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一个高增益光晶体管输出的光耦器件,具有快速响应时间和高输入输出隔离电压。
3. 引脚分配:EL817有6个引脚,包括发光二极管的阳极、阴极和GND,以及光晶体管的集电极、发射极和GND。
4. 参数特性:包括最大正向电流、最大反向电压、最大功率耗散等。
5. 功能详解:EL817通过输入电流控制发光二极管发光,光晶体管根据接收到的光信号导通或截止。
6. 应用信息:适用于隔离开关、接口电路、数字通信等。
7. 封装信息:EL817采用DIP-6封装。
CONREVSMA005-R178 价格&库存
很抱歉,暂时无法提供与“CONREVSMA005-R178”相匹配的价格&库存,您可以联系我们找货
