CONREVMCX007
CONREVMCX007
    LINXTECHNOLOGIES(灵思)
    RP-MCX
CONREVMCX007 数据手册
Description Body Socket Insulation Crimp Ring Boyd Chuck Heat Shrink Material Brass BE CU PTFE Brass BE CU Polyolefin Finish Nickel Gold N/A Gold Gold Black REVISIONS REV HEAT SHRINK B Ø0.197 (5.00) SIDE VIEW APPV Added new title block and heat shrink; Updated instructions 11-JUL-12 SAH SOCKET 0.3x3.9x5 GROOVE Ø0.148 (3.75) Ø0.102 (2.60) Ø0.197 (5.00) CRIMP RING PIN CHUCK 0.2x2x2 GROOVE 0.244 (6.20) 0.126 (3.20) DATE 0.787 (20.00) BOYD CHUCK 0.165 (4.20) DESCRIPTION Ø0.154 (3.90) Ø0.037 (0.95) 0.276 (7.00) 0.197 (5.00) 0.488 (12.40) CONREVMCX007 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. Strip the cable to the recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Solder the socket to the center conductor. Insert the socket, center conductor, and insulator into the body until the socket snaps in. Wrap the braid around the tail of the body and crimp the ring with a 0.128" hex crimp tool (or one labeled for use with RG-174 cable). Use heat shrink to cover crimp. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.079 0.079 (2.00) (2.00) 0.217 (5.50) RG-174 Cable NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 159 ORT LANE MERLIN, OR 97532 TITLE: RP-MCX MALE CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVMCX007 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVMCX007 价格&库存
很抱歉,暂时无法提供与“CONREVMCX007”相匹配的价格&库存,您可以联系我们找货
