810PE205A
810PE205A
    WINCHESTER(温彻斯特)
    F MALE PUSH-EZ RG6 GOLD PLATED
810PE205A 数据手册
- Page 24 - Specifications for "F" Connectors _____________________________ F style connectors are the least expensive, general purpose connectors with non-constant impedance for use at 500 volts or less, and for use with low frequencies to 500Mhz. These coaxial connectors are widely used in Cable TV, MATV, CCTV, and related consumer television products. They are available in a limited selection to fit various cable sizes. NOTE: See V-Bite 861V509ER6 -40dB @ 2.3GHz MATERIALS Connector Parts Connector Body and Parts Male Contact Pin Insulators Plating Ferrule Material Brass Brass Polypropylene Nickel Annealed Copper ELECTRICAL Requirement Impedance Frequency Range VSWR Working Voltage (At Sea level) Insulation Resistance Contact Resistance Test Voltage Performance Non Constant 0-500MHz (see below 861V509ER6 to 3GHz) 1.5 Max. 500V rms 5000 Megohm Min. 3 mW Max. 1000V r.m.s MECHANICAL & ENVIRONMENTAL Requirement Durability Shock Cable Retention Temperature Range Moisture Range Performance 500 Matings 30 G 40 Lbs. Min. -40 to +65°C. Continuous Test s _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 back to index 24 - Page 25 - "F" Connectors _____________________________ Plugs, Jacks, Adapters F type plugs are available in three different crimp styles: two piece with separate ferrules, one piece crimp with a short crimp body and a one piece crimp with a long body. Also, a twist-on type for tool-less installations. Jacks for bulkhead, inline, or PC board, and a variety of adapters are all machined brass construction. Part Number Description 810A209A 810A209D 810A209G 810B209G 810D209A 810A209MV 810D209D 810D209G 810E209A 810E209D 810E209G 810A409A 810A409G 810P209A 810P209G 816B519 826B519 832A519N 830A509 831B509 832A519 843A509 845A509 851A509 F0884 2 Piece Crimp Plug, Short Ferrule 2 Piece Crimp Plug, Short Ferrule 2 Piece Crimp Plug, Short Ferrule 2 Piece Crimp Plug, Long Ferrule 2 Piece Crimp Plug, Short Ferrule 4 Pc Crimp Mini Coax. Uses BD11007 Tool 1 Piece Crimp Plug, Short Ferrule 1 Piece Crimp Plug, Short Ferrule 1 Piece Crimp Plug, Long Ferrule 1 Piece Crimp Plug, Long Ferrule 1 Piece Crimp Plug, Long Ferrule Twist-On Twist-On Push-On Push-On Male Bulkhead Receptacle. 3/8-32 THD I.D. Bulkhead Jack, Solder Tab Inline Female/Female W/Nut &Washer Inline, Male/Male Inline Female/Male Push-On Inline Female/Female “T” Adapter, Female/Male/Female “T” Adapter, Female/Female/Female Right Angle Adapter, Male/Female 75 Ohm Male Terminator RoHS compliant REQUEST QUOTE RG/U Cable 6 11 59 59 6 174 11 59 6 11 59 6 59 6 59 Any Any N/A N/A N/A N/A N/A N/A N/A N/A Fig. No. 117 117 117 118 117 117A 119 119 120 120 120 121 121 122 122 130A 123 124 125 125A 126 127 128 129 130 Fig. 117 Fig. 117A Fig. 118 Fig. 119 Fig. 120 Fig. 121 Also See Push-EZ™ Next Page Fig. 122 Fig. 123 Fig. 124 Adapters & Terminators REQUEST DRAWING Fig. 125 Fig. 127 Fig. 126 Fig. 125A Fig. 128 s This recessed male acts as a jack & allows for a replaceable female end by using a 832A519 adapter. Also, this can be used to accommodate any adapter with a female F interface on one side. The other end can be BNC, TNC, or any style available. (See adapter pages) Fig. 129 ss Fig. 130A2 3/8 - 32 Internal Thd. ½ - External Thd. s Fig. 130 s _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 back to index 25 - Page 26 - __________________________ Push EZ™ “F” Plugs With LIFT™ Bomar’s exclusive LIFT® Technology (Low Insertion Force Termination) is used in the patented Push-EZ™ connector. It installs by simply stripping the cable and inserting it into the connector. That’s it. And it will not pull out. No crimp tooling required. s Part Number 810PE209A 810PE209G 810PE205A 810PE205G RG/U Body Cable Plating Description Push-EZ™ Plug with LIFT® Technology Push-EZ™ Plug with LIFT® Technology Push-EZ™ Plug with LIFT® Technology Push-EZ™ Plug with LIFT® Technology RoHS compliant REQUEST QUOTE 6 59 6 59 Nickel Nickel Gold Gold REQUEST DRAWING PC Board Connectors Part Number 861A509 861V509E 861V509ER 861V509ER6 864B509 864B509HF 864B509S 866B509 Description PC Board Jack, Vertical V-Bite™ Edge Mount PC Jack V-Bite™ Reflow Type w/ TFE Insulator RG59 V-Bite™ Reflow Type w/ TFE Insulator RG6/59 (3GHz) PC Board Jack, Right Angle, Long PC Board Jack, Right Angle, Long (3GHz) PC Board Jack, Right Angle, Short PC Board Male, Right Angle The Eliminator™ RoHS compliant reflow or wave solder only REQUEST QUOTE RG/U Fig. Cable No. N/A N/A N/A 131 131V 131V N/A 131V N/A N/A N/A N/A 132 132 133 136B RoHS compliant wave solder REQUEST DRAWING Fig. 131 Fig. 132 Fig. 133 Fig. 135B The V-Bite™ V-Bite™ Mounts on the PC board edge and is extremely anti-rotational. It locks into the board for soldering. Available in reflow soldering version. Fig. 131V V-Bite™ Mounts on the PC board edge and is extremely antirotational. It locks into the board for soldering. Available in reflow soldering version. PCB Layout 864B Series _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 - Page 27 - back to index 26
810PE205A 价格&库存
很抱歉,暂时无法提供与“810PE205A”相匹配的价格&库存,您可以联系我们找货
