H.FL75-CONTACT
H.FL75-CONTACT
    HRS(广濑)
    CONN CONTACT
H.FL75-CONTACT 数据手册
NEW 75 Ω Small Coaxial Connectors (SMT Low Profile) H.FL75 Series 75 ø, up to 3 GHz Figure 1 Connector mating external view 3 6.5 H.FL75-LP(G)-084 H.FL-R-SMT Figureq ■Features 1. Miniature, 75Ω coaxial RF connector A mated receptacle and right-angled plug delivers a low mated height of only 3 mm from the printed circuit board (see Fig. q). 2. High impedance matching High impedance matching is used to produce its high frequency response from DC to 3 GHz, which is suitable for 3G-SDI broadcasting equipment. 3. Terminated with 75 Ω, ultra-fine coaxial cable The use of Ø1.5 mm, ultra-fine coaxial (fluorinated resin insulated) cables make this connector perfect for applications that require wiring in tight spaces. 5. Supports automatic mounting The receptacles are packaged on reels which supports automatic pick-and-place mounting. Capped receptacles are available and are suitable for use with vir tually all types of mounting machines. 6. Easy mating with protected design The design structure emits a clear tactile click when mating is completed. Even though small in size, the receptacle’s design adds extra protection to the mating area. 7. Simple un-mating process An extraction tool is available which simplifies the un-mating process. 4.Suitable for use with 3G-SDI equipment Used together with BNC (75) Series connectors, it’s possible to maintain 75 ø system lines from the interface connections to the internal wiring systems. Internal wiring: H.FL75 Series Interface: BNC (75) Series 2014.3 1 H.FL75 Series●75 Ω Small Coaxial Connectors (SMT Low Profile) ■Product Specifications Nominal characteristic impedance: 75 ø Ratings Voltage: AC 60 V rms Frequency range: DC to 3 GHz Items Operating temperature range: -40ç to +90ç (RH 90% max.) Storage temperature range: -30ç to +70ç (RH 90% max.) Specifications Conditions 1. Contact resistance Center:Maximum of 20 mø Outer: Maximum of 10 mø Measured with 10 mA max. 2. Insulation resistance Minimum of 500 Mø Measured with 250 VDC 3. Withstanding voltage 4. V.S.W.R. (*) No flashover or insulation breakdown AC 300 V / 1 minute. Maximum of 1.25 DC to 1.5 GHz Maximum of 1.5 1.5 to 3 GHz 5. Holding power of female contact Minimum of 0.15 N Measured withØ0.475 pin gauge. 6. Total mating/ unmating force Maximum of 30 N Measured with applicable connector. 7. Durability (mating/ unmating with corresponding plug) Contact resistance Center: Maximum of 25 mø Outer: Maximum of 15 mø 50 mating cycles. 8. Vibration resistance No electrical discontinuity for 1 µs or more. No damaged, cracks or loose parts. Frequency of 10 to 100 Hz, single amplitude of 1.5 mm, acceleration of 59 m/s2, for 5 cycles in each of the 3 axes direction. 9. Shock resistance No electrical discontinuity for 1 µs or more. No damaged, cracked or loose parts. Acceleration of 735 m/s2, for a duration of 11 ms, sine half-wave waveform, 3 cycles in each of the 6 axes direction. 10. Humidity resistance (Steady state) No damaged, cracked or loose parts Insulation resistance: 10 Mø min. (high humidity) Insulation resistance: 500 Mø min. (dry) 96 hours at temperature of 40ç and humidity of 95% . 11. Temperature cycle No damaged, cracked or loose parts. Contact resistance Center: Maximum of 25 mø Outer: Maximum of 15 mø Temperature: -40ç → +5 to +35ç → +90ç → +5 to +35ç Time: 30 → 5 max. → 30 → 5 max. (minutes) 5 Cycles 12. Salt spray No excessive corrosion 5% salt water solution for 48 consecutive hours *V.S.W.R. Measurement System The above V.S.W.R. specification values were measured using the measurement system shown below. Network Analyzer Test Set Test Port Test Port Cable D.U.T Termination Note 1: Cable type connectors were measured with BNC (75) conversion adapters attached to both ends of the harness product of a suitable 10 cm cable. Note 2: Board type connectors were mounted to a 75 ø glass epoxy board and measurements were conducted with N (75) connectors attached. ■Materials Part Shell Male center contact Female center contact Insulator Material Phosphor bronze Brass Phosphor bronze Plug PBT Resin Receptacle LCP Finish Silver plated Gold plated Gold plated Black Black Remarks — — — UL94V-0 UL94V-0 ■Plug 6.5 75 [Plugs are only sold as cabled assemblies] 2 H.FL75 Series●75 Ω Small Coaxial Connectors (SMT Low Profile) ■How to Specify Plug Cable Assembly The dimensions of a cable assembly of the H.FL75 series should be specified as follows: [Single-Ended Cable Assembly] [Double-Ended Cable Assembly] L(mm) L(mm) ■Product Number Structure of Cable Assemblies ■Standard Tolerances for (L) Refer to this page when determining product specifications by model types. Please place orders with part numbers listed in this catalog. The characteristics and specifications of the product described in this catalog are reference values. Please make sure to check the latest delivery specifications at the time of product use. 35 ≦ L ≦ 200 Standard Tolerance (mm) ±4 200 < L ≦ 500 ±8 L (mm) 500 < L ≦ 1000 ±12 1000 < L ±1.5% of L Note: 35 mm is the shortest length (L) that can be made. H.FL75 -「」LPG -「」- A - (L) ❶ ❷ ❸ ❹ ❶ Series name H.FL75 ❷ Assembly type None: Single-ended, 2: Double-ended ❸ Cable type 084N: for Ø1.5 mm cable ❹ Cable color 1: White, 2: Black, 4: Blue ❺ Total length L (mm) L length in mm ■Receptacle With cap installed GND GND GND SIG 1.7 HRS No. Packaging Remarks H.FL-R-SMT(01) CL331-0521-6-01 100 pieces per pack − H.FL-R-SMT(10) CL331-0521-6-10 2,500 pieces per reel − H.FL-R-SMT(C)(10) CL331-0522-9-10 2,500 pieces per reel With caps 1±0.05 Recommended PCB layout dimensions 3±0.05 2.8±0.05 3-0.8 (Note 3) 5 4.5 0.6 2±0.05 GND 1.5±0.05 Part No. Cap Ø0.5 4.5 4 Note 1: Receptacles that are specified by (01) are sold in 100 piece packs. Please order in full pack quantities. Note 2: Receptacles that are specified by (10) are sold in full reel quantities, each reel contains 2,500 pieces. Please order in full reel quantities. Note 3: This area may be covered by insulating material. Note 4: The H.FL-R-SMT (C) (10) comes equipped with a cap that allows it to be mounted by almost any pick and place machine. Remove cap after the reflow process. Maximum of 1.5 Ø2.4 3-1.2±0.05 GND GND SIG 1.2±0.05 3.1±0.05 3.1±0.05 3 H.FL75 Series●75 Ω Small Coaxial Connectors (SMT Low Profile) BEmbossed Carrier Tape Dimensions (JIS-C-0806 compliant) 1.75 The diagram below shows the embossed carrier tape dimensions used to package the H.FL-R-SMT(10). Ø1.5 2 4 Reel Dimensions 2 Center contact 14 3 Ø1 12 Ø330 5.5 Ø21 8 (2.4) Unreeling direction ■Conversion Adapter φ2.4 ●BNC (75) Conversion Adapter (Mating portion - H.FL75 side: jack - BNC (75) side: jack) φ13 8.2 +00.1 + 0 0 .1 12.5 φ 9. 6 21.3 Part No. BNC(75)J-H.FLJ-BPA(40) HRS No. RoHS CL311-0302-8-40 ○ BPlug Extraction Tool 5 Ø1 3.3 6 This is the recommended tool for un-mating the plug when in the mated condition. 100 3 40 Part No. H.FL-LP-N HRS No. RoHS CL331-0551-7 ○ 4 H.FL75 Series●75 Ω Small Coaxial Connectors (SMT Low Profile) BUsage Precautions 1.Plugs (1) Mating / un-mating qTo disconnect the connector, insert the extraction tool (H.FL-LP-N) under the connector flange. Pull in a perpendicular direction, or in the direction of the connectors mating axis. Do not un-mate the plug by pulling on the cable, this can damage the connector and alter its performance. wTo mate the connector, align the mating axes between the receptacle and cable assembly, and insert the cable assembly downward and perpendicular into the receptacle. Do not insert the cable assembly at a slanted angle. (2) Allowable load to a cable when mated. After the connector has been mated, prevent excessive force being placed onto the cable. Please reference the tolerances listed below. Maximum of 3 N Maximum of 5 N H.FL-LP* H.FL-R-SMT Maximum of 3 N (3) Precautions Do not use excessive prying forces to mate or un-mate these connectors, failure to follow this precaution can lead to the connector becoming damaged. 2. Receptacles Reflow temperature profile (reference) [ç ] Temperature (1) Recommended reflow temperature profile[reference] 260 240 220 200 180 160 140 120 100 80 Peak temperature 250ç, 10 seconds 230ç 220ç Maximum of 50 seconds Maximum of 120 seconds Maximum of 60 seconds Time qThe temperatures indicated are the surface temperatures of the printed circuit board near the terminal contact points. wReflow soldering should be performed at a peak temperature of 250ç or less at the surface of the printed circuit board. eTemperature profiles may vary due to external mounting conditions; conditions such as solder paste types, manufacturer, PCB size and any other soldering materials may alter the performance of such materials. (2) Recommended manual soldering [reference] Soldering iron temperature: 350ç, soldering time: Maximum of 5 seconds. (3) Recommended metal mask thickness 0.1 to 0.15 mm (4) Reflow cycles Maximum of 2 cycles 3.Operating Environment and Storage Conditions (1) Operating environment (2) Storage conditions This product was designed on the assumption that it will be used in a normal environment. Please be advised that using these connectors in certain environments may lead to discoloration or other types of degradation. ・Exposed to a excessive amounts of fine particles and dust ・Regions and places having a high density of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive gasses. (e.g., exhaust gas from automobiles or factories) ・Environments that experience large changes in temperatures, such as locations near a heater. Store the product in Hirose Electric's packaging or similar packaging conditions. Temperature: -10 to +40ç, humidity: 85% or less (recommended storage conditions) We recommend that this product be consumed within six months from delivery. For products that have been stored and the storage period has expired, they need to be tested for solderability before use. 5 H.FL75 Series●75 Ω Small Coaxial Connectors (SMT Low Profile) BHigh Frequency Characteristics of related 75 Ω Hirose products 2 ●BNC (75) Series 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ BNC(75)-BPJ-1.5CV-※ 1.2 1.1 1 0 0.5 1 1.5 2 2.5 3 2 2.5 3 2 2.5 3 2 2.5 3 Frequency[GHz] 2 ●PL71 Series 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ PL71-LP-1.5C(40) 1.2 1.1 1 0 0.5 1 1.5 Frequency[GHz] 2 ●PL75 Series 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ PL71-LP-1.5CV 1.2 1.1 1 0 0.5 1 1.5 Frequency[GHz] 2 ●H.FL75 Series 1.9 1.8 H.FL75-2LPG-084N※-L V.S.W.R. 1.7 100 1.6 1.5 1.4 1.3 1.2 1.1 BNC(75)J-H.FLJ-BPA(40) 1 0 0.5 1 1.5 Frequency[GHz] ® 6 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
H.FL75-CONTACT 价格&库存
很抱歉,暂时无法提供与“H.FL75-CONTACT”相匹配的价格&库存,您可以联系我们找货
