NEW
75 Ω Small Coaxial Connectors (SMT Low Profile)
H.FL75 Series
75 ø, up to 3 GHz
Figure 1 Connector mating external view
3
6.5
H.FL75-LP(G)-084
H.FL-R-SMT
Figureq
■Features
1. Miniature, 75Ω coaxial RF connector
A mated receptacle and right-angled plug
delivers a low mated height of only 3 mm from
the printed circuit board (see Fig. q).
2. High impedance matching
High impedance matching is used to produce its
high frequency response from DC to 3 GHz,
which is suitable for 3G-SDI broadcasting
equipment.
3. Terminated with 75 Ω, ultra-fine coaxial cable
The use of Ø1.5 mm, ultra-fine coaxial (fluorinated
resin insulated) cables make this connector
perfect for applications that require wiring in tight
spaces.
5. Supports automatic mounting
The receptacles are packaged on reels which
supports automatic pick-and-place mounting.
Capped receptacles are available and are
suitable for use with vir tually all types of
mounting machines.
6. Easy mating with protected design
The design structure emits a clear tactile click
when mating is completed. Even though small
in size, the receptacle’s design adds extra
protection to the mating area.
7. Simple un-mating process
An extraction tool is available which simplifies
the un-mating process.
4.Suitable for use with 3G-SDI equipment
Used together with BNC (75) Series connectors,
it’s possible to maintain 75 ø system lines from
the interface connections to the internal wiring
systems.
Internal wiring: H.FL75 Series
Interface: BNC (75) Series
2014.3
1
H.FL75 Series●75 Ω Small Coaxial Connectors (SMT Low Profile)
■Product Specifications
Nominal characteristic impedance: 75 ø
Ratings
Voltage: AC 60 V rms
Frequency range: DC to 3 GHz
Items
Operating temperature range: -40ç to +90ç (RH 90% max.)
Storage temperature range: -30ç to +70ç (RH 90% max.)
Specifications
Conditions
1. Contact resistance
Center:Maximum of 20 mø
Outer: Maximum of 10 mø
Measured with 10 mA max.
2. Insulation resistance
Minimum of 500 Mø
Measured with 250 VDC
3. Withstanding voltage
4. V.S.W.R. (*)
No flashover or insulation breakdown
AC 300 V / 1 minute.
Maximum of 1.25
DC to 1.5 GHz
Maximum of 1.5
1.5 to 3 GHz
5. Holding power of
female contact
Minimum of 0.15 N
Measured withØ0.475 pin gauge.
6. Total mating/
unmating force
Maximum of 30 N
Measured with applicable connector.
7. Durability (mating/
unmating with
corresponding plug)
Contact resistance
Center: Maximum of 25 mø
Outer: Maximum of 15 mø
50 mating cycles.
8. Vibration resistance
No electrical discontinuity for 1 µs or more.
No damaged, cracks or loose parts.
Frequency of 10 to 100 Hz, single amplitude of 1.5
mm, acceleration of 59 m/s2, for 5 cycles in each
of the 3 axes direction.
9. Shock resistance
No damaged, cracked or loose parts.
Acceleration of 735 m/s2, for a duration of 11 ms,
sine half-wave waveform, 3 cycles in each of the 6
axes direction.
10. Humidity resistance
(Steady state)
Insulation resistance: 10 Mø min. (high humidity)
Insulation resistance: 500 Mø min. (dry)
96 hours at temperature of 40ç and humidity of
95% .
11. Temperature cycle
Contact resistance
Temperature: -40ç → +5 to +35ç → +90ç →
+5 to +35ç
Time: 30 → 5 max. → 30 → 5 max. (minutes)
5 Cycles
12. Salt spray
No excessive corrosion
5% salt water solution for 48 consecutive hours
*V.S.W.R. Measurement System
The above V.S.W.R. specification values were measured using the measurement system shown below.
Network Analyzer
Test Set
Test Port
Test Port Cable
D.U.T Termination
Note 1: Cable type connectors were measured with BNC (75) conversion adapters
attached to both ends of the harness product of a suitable 10 cm cable.
Note 2: Board type connectors were mounted to a 75 ø glass epoxy board
and measurements were conducted with N (75) connectors attached.
■Materials
Part
Shell
Male center contact
Female center contact
Insulator
Material
Phosphor bronze
Brass
Phosphor bronze
Plug
PBT Resin
Receptacle
LCP
Finish
Silver plated
Gold plated
Gold plated
Black
Black
Remarks
UL94V-0
UL94V-0
■Plug
6.5
75
[Plugs are only sold as cabled assemblies]
2
■How to Specify Plug Cable Assembly
The dimensions of a cable assembly of the H.FL75 series should be specified as follows:
[Single-Ended Cable Assembly]
[Double-Ended Cable Assembly]
L(mm)
L(mm)
■Product Number Structure of
Cable Assemblies
■Standard Tolerances for (L)
Refer to this page when determining product specifications
by model types. Please place orders with part numbers
listed in this catalog. The characteristics and specifications
of the product described in this catalog are reference
values. Please make sure to check the latest delivery
specifications at the time of product use.
35 ≦ L ≦ 200
Standard Tolerance
(mm)
±4
200 < L ≦ 500
±8
L (mm)
500 < L ≦ 1000
±12
1000 < L
±1.5% of L
Note: 35 mm is the shortest length (L) that can be made.
H.FL75 -「」LPG -「」- A - (L)
❶
❷
❸
❹
❶ Series name
H.FL75
❷ Assembly type
None: Single-ended,
2: Double-ended
❸ Cable type
084N: for Ø1.5 mm cable
❹ Cable color
1: White, 2: Black, 4: Blue
❺ Total length L (mm)
L length in mm
■Receptacle
With cap
installed
GND
GND
GND
SIG
1.7
HRS No.
Packaging
Remarks
H.FL-R-SMT(01)
CL331-0521-6-01
100 pieces per pack
H.FL-R-SMT(10)
CL331-0521-6-10
2,500 pieces per reel
H.FL-R-SMT(C)(10)
CL331-0522-9-10
With caps
1±0.05
Recommended PCB
layout dimensions
3±0.05 2.8±0.05
3-0.8
(Note 3)
5
4.5
0.6
2±0.05
GND
1.5±0.05
Part No.
Cap
Ø0.5
4.5
4
Note 1: Receptacles that are specified by (01) are sold in 100 piece packs.
Please order in full pack quantities.
Note 2: Receptacles that are specified by (10) are sold in full reel
quantities, each reel contains 2,500 pieces.
Please order in full reel quantities.
Note 3: This area may be covered by insulating material.
Note 4: The H.FL-R-SMT (C) (10) comes equipped with a cap that
allows it to be mounted by almost any pick and place machine.
Remove cap after the reflow process.
Maximum of 1.5
Ø2.4
3-1.2±0.05
GND
GND
SIG
1.2±0.05
3.1±0.05
3.1±0.05
3
BEmbossed Carrier Tape Dimensions (JIS-C-0806 compliant)
1.75
The diagram below shows the embossed carrier tape dimensions used to package the H.FL-R-SMT(10).
Ø1.5
2
4
Reel Dimensions
2
Center contact
14
3
Ø1
12
Ø330
5.5
Ø21
8
(2.4)
Unreeling direction
■Conversion Adapter
φ2.4
●BNC (75) Conversion Adapter (Mating portion - H.FL75 side: jack - BNC (75) side: jack)
φ13
8.2 +00.1
12.5
φ
9.
6
21.3
Part No.
BNC(75)J-H.FLJ-BPA(40)
HRS No.
RoHS
CL311-0302-8-40
BPlug Extraction Tool
5
Ø1
3.3
6
This is the recommended tool for un-mating the plug when in the mated condition.
100
3
40
Part No.
H.FL-LP-N
HRS No.
RoHS
CL331-0551-7
4
BUsage Precautions
1.Plugs
(1) Mating / un-mating
qTo disconnect the connector, insert the extraction tool (H.FL-LP-N) under
the connector flange. Pull in a perpendicular direction, or in the direction
of the connectors mating axis.
Do not un-mate the plug by pulling on the cable, this can damage the
connector and alter its performance.
wTo mate the connector, align the mating axes between the receptacle
and cable assembly, and insert the cable assembly downward and
perpendicular into the receptacle.
Do not insert the cable assembly at a slanted angle.
(2) Allowable load to a cable when
mated.
After the connector has been mated, prevent excessive force being
placed onto the cable. Please reference the tolerances listed below.
Maximum
of 3 N
Maximum
of 5 N
H.FL-LP*
H.FL-R-SMT
Maximum
of 3 N
(3) Precautions
Do not use excessive prying forces to mate or un-mate these connectors, failure
to follow this precaution can lead to the connector becoming damaged.
2. Receptacles
Reflow temperature profile (reference)
[ç ]
Temperature
(1) Recommended reflow
temperature profile[reference]
260
240
220
200
180
160
140
120
100
80
Peak temperature
250ç, 10 seconds
230ç
220ç
Maximum of 50 seconds
Maximum of 120 seconds
Maximum of 60 seconds
Time
qThe temperatures indicated are the surface temperatures of the
printed circuit board near the terminal contact points.
wReflow soldering should be performed at a peak temperature of
250ç or less at the surface of the printed circuit board.
eTemperature profiles may vary due to external mounting conditions;
conditions such as solder paste types, manufacturer, PCB size and
any other soldering materials may alter the performance of such
materials.
(2) Recommended manual
soldering [reference]
Soldering iron temperature: 350ç, soldering time: Maximum of 5
seconds.
(3) Recommended metal mask thickness
0.1 to 0.15 mm
(4) Reflow cycles
Maximum of 2 cycles
3.Operating Environment and Storage Conditions
(1) Operating environment
(2) Storage conditions
This product was designed on the assumption that it will be used in a
normal environment.
Please be advised that using these connectors in certain environments
may lead to discoloration or other types of degradation.
・Exposed to a excessive amounts of fine particles and dust
・Regions and places having a high density of sulfur dioxide, hydrogen
sulfide, nitrogen dioxide or other corrosive gasses. (e.g., exhaust gas
from automobiles or factories)
・Environments that experience large changes in temperatures, such as
locations near a heater.
Store the product in Hirose Electric's packaging or similar packaging conditions.
Temperature: -10 to +40ç, humidity: 85% or less (recommended storage
conditions)
We recommend that this product be consumed within six months from delivery.
For products that have been stored and the storage period has expired, they
need to be tested for solderability before use.
5
BHigh Frequency Characteristics of related 75 Ω Hirose products
2
●BNC (75) Series
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
BNC(75)-BPJ-1.5CV-※
1.2
1.1
1
1
1.5
2
2.5
3
2
2.5
3
2
2.5
3
2
2.5
3
Frequency[GHz]
2
●PL71 Series
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
PL71-LP-1.5C(40)
1.2
1.1
1
1
1.5
Frequency[GHz]
2
●PL75 Series
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
PL71-LP-1.5CV
1.2
1.1
1
1
1.5
Frequency[GHz]
2
●H.FL75 Series
1.9
1.8
H.FL75-2LPG-084N※-L
V.S.W.R.
1.7
100
1.6
1.5
1.4
1.3
1.2
1.1
1
1
1.5
Frequency[GHz]
6
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“H.FL75-LP-084(01)”相匹配的价格&库存,您可以联系我们找货
