8001-4103
8001-4103
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSOCKETCONTACTGOLD
8001-4103 数据手册
EXPIRED REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING B REV. DCN 32852 DATE APPROVED 03/05 VMJ .286±.002 .405 MIN. +.001 .315 - .002 MATERIALS: INSULATORS: BODY: +.002 .274 - .003 .031±.002 .186±.019 PTFE PER ASTM D1710, TYPE 1, GRADE 1, CLASS B. .180 BRASS PER ASTM B16, ALLOY UNS C36000, H02 BODY & CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY C17300, COND. TD04 SHRINK TUBING: POLYEFIN PER SAE AMS-DTL-23053/5-106-0 .146±.001 .0355±.0010 FINISHES: BODIES & CONTACT: GOLD PER ASTM B488, TYPE II, GRADE C, CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290 CLASS 1, .00005" MIN. .263 .002 ELECTRICAL: IMPEDANCE: FREQ. RANGE: INSUL. RES.: D.W.V: VSWR: INSERTION LOSS: .198 MIN. .290±.020 .562 MAX. .625±.006 50 OHMS DC TO 3 GHz 5,000 MEGOHMS MIN. 1,000 VRMS MIN. 1.20 + .04 X F IN GHz .11 X SQUARE ROOT OF F(GHz) (MAX FREQ. CAN BE LIMITED BY CABLE) REF. AS39029/59 & MIL-DTL-38999 SERIES III MATERIAL: SEE ABOVE DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: FINISH: SEE ABOVE PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE AFTER PLATING. 2) BREAK CORNERS & EDGES .005 R. MAX. 3) CHAM. 1ST & LAST THREADS. 4) SURFACE ROUGHNESS 63 MIL-STD-10. 5) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 6) REMOVE ALL BURRS DRAWN: VMJ 11/30/04 CHECKED: APPROVED: JMC 11/30/04 JMC 11/30/04 E.M. SIMULATION: N/A SV Microwave, Inc. 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SIZE 8 SOCKET FOR T-FLEX 402 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 8001-4103 SHEET 1 OF 1
8001-4103 价格&库存
很抱歉,暂时无法提供与“8001-4103”相匹配的价格&库存,您可以联系我们找货
