ABF.00.250.NTA
ABF.00.250.NTA
    LEMO(雷莫)
    CONN ADAPT PLUG TO BNC JACK
ABF.00.250.NTA 数据手册
ABF.00.250.NTA www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Coupler/adapter/bridge IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts ERA.00.250.NTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ABF*: Adapter from LEMO plug to BNC receptacle Keying Circular, male Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 8.17 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm Contact Dia.: 0.7 mm (0.03in) Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Endurance (Shell): >1000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L M mm. 11.5 36 28 in. 0,45 1,42 1,10 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
ABF.00.250.NTA 价格&库存
很抱歉,暂时无法提供与“ABF.00.250.NTA”相匹配的价格&库存,您可以联系我们找货
