RMA.00.250.CTM
RMA.00.250.CTM
    LEMO(雷莫)
    RMA.00.250.CTM
RMA.00.250.CTM 数据手册
RMA.00.250.CTM www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Coupler/adapter/bridge IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model RMA*: Free coupler Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 2.58 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm Contact Retention: 18 N Contact Dia.: 0.7 mm (0.03in) Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L mm. 6.5 22 in. 0,26 0,87 RECOMMENDED BY LEMO Tools Crimp Tool: DPC.91.701.V LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
RMA.00.250.CTM 价格&库存
很抱歉,暂时无法提供与“RMA.00.250.CTM”相匹配的价格&库存,您可以联系我们找货
RMA.00.250.CTM
  • 1+136.42127
  • 10+132.32863
  • 50+128.24641
  • 100+125.52840
  • 250+122.77914
库存:60
