REVISION B
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
SMP-J-B-XX-ST-XXXX
DO NOT
SCALE FROM
THIS PRINT
GENDER
-J: JACK
B
TYPE
-B: BULLET
C
+0.12
0.05 - 0.05
LENGTH
-0645: 6.45MM
*-0700: 7.00MM
*-1000: 10.00MM
-1450: 14.50MM
+0.12
1
+.005
.002 - .002
2
ORIENTATION
-ST: STRAIGHT
PLATING SPECIFICATION
(VALUES GIVEN ARE IN MICRO-INCHES)
-HG: HEAVY GOLD / GOLD
30 Au / 50 Ni MIN ON PIN
10 Au / 50 Ni MIN ON OUTER CONTACT
-GF: GOLD / FLASH GOLD
10 Au / 50 Ni MIN ON PIN
3 Au / 50 Ni MIN ON OUTER CONTACT
(SEE TABLE 1)
* = NOT TOOLED
+.005
0.05 - 0.05 .002 - .002
(FROM SHELL TO CONTACT)
3
(FROM SHELL TO INSULATOR,
SEE NOTE 4)
B
C
+0.12
+.005
(FROM SHELL TO INSULATOR)
SECTION "A"-"A"
B
C
+0.25
+.010
"B" 0.00 "B" - .000
(RECOMMENDED
PLUG TO PLUG SPACING)
"A"
"A"
3.40 .134
REF
"A" REF
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE FOR CENTER CONTACT: 6.67 N [1.5 LB].
INSULATOR: 6.67 N [1.5 LB].
3. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-HD-WI-3040-M.
TRAY: TY-SMA001-1
COVER: TY-SMA001-2
-0645: 500 PARTS PER TRAY(5 PARTS PER POCKET),
-0700, -1000 & -1450: 300 PARTS PER TRAY(3 PARTS PER POCKET)
4. APPLICABLE ON -1450 LENGTH ONLY.
F:\DWG\MISC\MKTG\SMP-J-B-XX-ST-XXXX-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
ANGLES
X.X: 0.3 [.01]
5
X.XX: 0.13 [.005]
X.XXX: 0.051 [.0020]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
PIN, SHELL: BeCu
INSULATOR: PTFE
SHEET SCALE: 8:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
SMP BULLET - 50 OHM
SMP-J-B-XX-ST-XXXX
BY: T MEEK
12/3/2010
SHEET 1 OF 2
REVISION B
IN-PROCESS 1
INSERT PIN / INSULATOR (1)
(-1450 OPTION ONLY)
"B"
"B"
SECTION "B"-"B"
PROPRIETARY NOTE
SHEET SCALE: 8:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SMP BULLET - 50 OHM
SMP-J-B-XX-ST-XXXX
BY: T MEEK
12/3/2010
SHEET 2 OF 2
很抱歉,暂时无法提供与“SMP-J-B-GF-ST-0645”相匹配的价格&库存,您可以联系我们找货
