ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
REV
PRODUCT DATA DRAWING
A
DCN 41734
DATE
APPROVED
10/15
STW
.813 20.65
.600 15.24
2X .312 7.92 HEX.
RP
RP
MATERIAL:
BODY &
COUPLING NUTS:
CONTACT &
LOCK RINGS:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
.218
ACROSS FLATS
.250 6.35
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
INSULATOR:
ULTEM 1000
GASKETS:
SILICONE RUBBER PER A-A-59588,
CLASS 2B, GRADE 60/70
FINISH:
BODY &
COUPLING NUTS:
CONTACT:
PASSIVATED PER AMS-2700
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
MATERIAL:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
FINISH:
50 OHMS
DC TO 40.0 GHz.
1.25:1 MAX. DC TO 40.0 GHz.
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FED 10/05/15
CHECKED:
APPROVED:
STW 10/05/15
STW 10/05/15
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
2.4mm PLUG TO SVK PLUG
STRAIGHT ADAPTER
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 8:1
SF1116-6007
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF1116-6007”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2195.031821+283.96088
- 10+1866.0380310+241.40051
- 25+1749.3664625+226.30726
- 50+1672.6270850+216.37985
