SF1158-6001
SF1158-6001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNADAPTBMAPLUGTOSMAJACK
SF1158-6001 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING A DCN 41727 DATE APPROVED 10/15 DAL .760 19.30 .447±.003 11.35±0.08 .156 MAX 3.96 MAX PANEL THICKNESS .065 1.65 BMA PLUG SMA JACK MATERIAL: 1/4-36 UNS-2A BODY& HEX NUT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLOUROCARBON PER AMS 7276 LOCK WASHER: 300 SERIES STAINLESS STEEL .437 11.10 HEX .312 HEX 1/4-36 UNS-2A TRUNCATED TO Ø.2395±.0015 FINISH: BODY, HEX NUT & LOCK WASHER: CONTACT: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: PERFORMANCE: FINISH: IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 18.0 GHz SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VMJ 10/24/96 CHECKED: APPROVED: GPF 10/15/15 STW 11/1/96 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA JACK TO BMA PLUG ADAPTER SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF1158-6001 SHEET 1 OF 1
SF1158-6001 价格&库存
很抱歉,暂时无法提供与“SF1158-6001”相匹配的价格&库存,您可以联系我们找货
