153215011
153215011
    WINCHESTER(温彻斯特)
    CONN ADAPT N JACK TO 7/16 JACK
153215011 数据手册
"Specialty Types" _____________________________ 7/16 DIN 7/16 DIN connectors are mechanically robust threaded coupling types designed for use with coaxial cables up to 17.3 mm dielectric diameter. Used in medium to high power applications in VHF and UHF fields. They are rated at 50 ohms and provide a low reflection factor up to 7.5 GHz. Various plating is available. All styles are currently built to order. N to 7/16 Part Number 131150011 153115011 153155011 153215011 RoHS compliant Description N Male - 7/16 Female (Tri-Plate) N Male - 7/16 Male (Tri-Plate) N Female - 7/16 Male (Tri-Plate) N Female - 7/16 Female (Tri-Plate) REQUEST QUOTE Fig. No. 155A 156A 157A 158A REQUEST DRAWING Fig. 155A Fig. 156A Fig. 157A Fig. 158 ____________________________ 7/16 to 7/16 Part Number 1513A5011 1532A5011 RoHS compliant Description 7/16 Male - 7/16 Female R/A (Tri-Plate) 7/16 Female -- 7/16 Female (Tri-Plate) REQUEST QUOTE Fig. No. 155B 156B REQUEST DRAWING Fig. 155B Fig. 156B ____________________________ 7/16 to N Adapter Kit 7/16 Adapter Kit ADPT3PA is a 8 piece kit containing 7/16 to N, N to N and 7/16 to 7/16 adapters. Made of machined brass and Tri-Plated bodies. Gold plated contacts. Kits are in zippered leather cases. Part Number ADPT3PA RoHS compliant Description 7/16 to NAdapter Kit (Tri-Plate) Fig. No. 155C REQUEST QUOTE Fig. 155C ____________________________ Cable End or Panel Mount Styles In some cases minimum order quantities will be required. These quantities will vary depending factors of tooling costs and total value. Contact Bomar Interconnect sales office with your inquiry. RoHS s GSK Style This style connector is used in video, cellular and other applications where blind mating or PC board stacking is required. The beryllium grounding spring on the female version allows for an excellent ground retension force. The contact mate is also rated for superior retention. Available with 15 amp contacts _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 back to index - Page 28 - 27
153215011 价格&库存
很抱歉,暂时无法提供与“153215011”相匹配的价格&库存,您可以联系我们找货
