CNMNM
CNMNM
    LAIRD(莱尔德)
    CONN ADAPT PLUG-PLUG N 50 OHM
CNMNM 数据手册
1 2 3 4 5 6 8 7 9 NOTES: ZONE 11 12 REV. DESCRIPTION DATE DRAWN BY ECR NUMBER A INITIAL DRAWING RELEASE 8/21/2012 PFR N/A SPECIFICATIONS: Impedance: 50 OHMS Frequency Range: 0-10 GHz VSWR: 0 - 7 GHz, 1.3 MAX. Working Voltage: 1000 V rms Max Insulation Resistance: 5k M Ohms min. A 10 REVISIONS A ALL DIMENSIONS ARE FOR REFERENCE ONLY NO. DESCRIPTION 1. BODY 2. PIN 3. INSULATION 4. CHASSIC 5. SHELL 6. RATAINING RING 7. GASKET B MATERIAL BRASS BRASS TEFLON BRASS BRASS BRASS SI-RUBBER Q' TY 1 1 2 2 2 2 2 FINISH NICKEL GOLD NONE NICKEL NICKEL NICKEL ORANGE B C C D D 20.0 E 20.0 E F F 40.6 G G MATERIAL: Notes: THE COMPONENTS(S), INCLUDING ANY PLATING, FINISHES, COATINGS, CHEMICALS AND SURFACES TREATMENTS, SUPPLIED IN THIS DOCUMENT/DRAWING MUST CONFORM AND COMPLY WITH THE LATEST ISSUE OF LAIRD TECHNOLOGIES SPECIFICATION LT-GES-001, WHICH FULLY INCLUDES BUT IS NOT LIMITED TO ALL CONTENTS OF EU DIRECTIVES 2002/96/EC (RoHS DIRECTIVE), AS WELL AS INCLUDES REQUIREMENTS OF THE JOINT INDUSTRY GUIDE STANDARD JIG-101, APRIL 2005. THE COMPONENT(S) IN THIS DOCUMENT/DRAWING MAY BE SUBJECT TO A FULL COMPOUND ANALYSIS FOR PROOF OF COMPLIANCE. THE LATEST ISSUE OF LAIRD TECHNOLOGIES SPECIFICATION LT-GES-001, (GENERAL SPECIFICATION FOR THE ENVIRONMENT) IS READILY AVAILABLE UPON REQUEST FROM THE SUPPLIER. H UNLESS OTHERWISE NOTED, THIS DOCUMENT CONTAINS LAIRD TECHNOLOGIES CONFIDENTIAL INFORMATION. REPRODUCTION, USE, DISCLOSURE OR TRANSMITTAL OF ALL OR ANY PART OF THIS DOCUMENT IS PROHIBITED EXCEPT TO THE EXTENT APPROVED IN WRITING BY AN AUTHORIZED REPRESENTATIVE OF LAIRD TECHNOLOGIES. LAIRD TECHNOLOGIES RESERVES ALL RIGHTS UNDER PATENTS, TRADEMARKS, COPY RIGHTS AND TRADE SECRETS. COPYRIGHT, LAIRD TECHNOLOGIES 2008, ALL RIGHTS RESERVED. 1 2 3 4 5 6 7 FINISH: SEE NOTES ME: RF: EM: Prod: WEIGHT: THIRD ANGLE PROJECTION SEE NOTES APPROVALS 1751 WILKENING COURT DATE SCHAUMBURG, IL 60173 USA INTERPRET DIMENSIONING AND TOLERANCING IN ACCORDANCE WITH ASME Y14.5M-1994 DO NOT SCALE DRAWING TOLERANCES UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS ANGLE: 0 PLACE DECIMAL: 1 PLACE DECIMAL: 2 PLACE DECIMAL: PREVIOUS# 30' 0.5 0.25 0.13 TITLE: MISCACC, ADP NM TO NM, ADP SIZE DWG NO. A3 SCALE: CNMNM SHEET 1 OF 1 REV A
CNMNM 价格&库存
很抱歉,暂时无法提供与“CNMNM”相匹配的价格&库存,您可以联系我们找货
