132A505
132A505
    WINCHESTER(温彻斯特)
    CONN ADAPT JACK-JACK N
132A505 数据手册
Specifications for "N" Connectors _____________________________ N Series connectors are medium sized, and weatherproof. The coupling method utilizes a screw system designed for use at frequencies up to microwave. These connectors are particularly useful where precision performance is necessary such as in test equipment, satellite communications, MATV, computer LAN systems, and other high-tech electronic equipment. Because of the quality manufacturing tolerances these connectors ensure excellent performance throughout 0-18GHz. MATERIALS Connector Parts Material Equivalent Standard † Connector Body and Parts Brass ISOCuZn38Pb2 Body Part Male Contact Pin Brass QQ-B-626 Outer Contact Brass QQ-B-750 Beryllium Copper Socket Contact Phosphor QQ-C-530/MIL-H-7199 Bronze CuBe2 Crimp Ferrule Annealed Copper QQ-C-576 Insulators, Standard Versions Teflon Delrin L-P403/BS4271 Rubber Gaskets Silicone Rubber ASTM-E1418PSI Plating Nickel (Silver Optional) MIL-G-45204 Grade B ELECTRICAL Requirement Test † Specification Performance Impedance 50  75 Frequency Range 0-18 GHz 0-1 GHz VSWR 1.30 Max. MIL- C-39012 RF Insertion Loss 0.2 db Max. at 3 GHz MIL- C-39012 RF Leakage -90 db Min. at 2-3 GHz MIL- C-39012 Test Voltage (At Sea Level) 2500V rms MIL-STD-202 Working Voltage (At Sea level) 1000V rms MIL-STD-202 Insulation Resistance 5000 Megohm Min. MIL-STD-202 Contact Resistance 3 Megohm Max. MIL-C-39012 --------- MECHANICAL & ENVIRONMENTAL Requirement Test † Specification Performance Durability 500 Insertions & Extractions Min. MIL-C-39012 Shock 100 G MIL-STD-202 Vibration 20 G from 80-2000 Hz MIL-STD-202 Cable Retention (Cable Types) 60 lbs. Minimum Pull Test MIL-C-39012 Coupling Nut 100 lbs. Maximum Teflon: -55 to +199 C Temperature Range MIL-C-39012 Delrin: -40 to ---------- +85 C Moisture Resistance Continuous Test MIL-STD-202 Salt Spray 48 Hours MIL-STD-202 s †Products are made to conform to the Mil standard but are for commercial applications and not QPL _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 18 s - Page 19 - "N" Connectors o ____________________________ Cable Plugs “N” cable plugs are available in solder/clamp, solder/crimp, and twist-on versions to satisfy the installer’s preference. Standard cable sizes are facilitated with these connectors for applications from satellite TV to Ethernet LAN installations. cmpliant Part Number Description RG/U Cable Fig. No. 110A108A Solder/Clamp Plug 6A 88 110A108B Solder/Clamp Plug 8, 213 88 110A108F Solder/Clamp Plug 58 88 110A108G Solder/Clamp Plug 59, 62 88 110A205A Solder/Crimp Plug 6A 89 110A205B Solder/Crimp Plug 8, 213 89 110A205F Solder/Crimp Plug 58 89 110A205G Solder/Crimp Plug 59, 62 89 110A404B2 Twist-On Plug Thick-Net 90 110A404B3 Twist-On Plug Thick-Net Plenum 90 Fig. 88 Fig. 89 Fig. 90 RoHS compliant REQUEST QUOTE REQUEST DRAWING Jacks Two cable jacks and one panel jack style are available as standard items. Other types are available as special order items. The cable jacks utilize the clamp/solder method of assembly and the panel jack will facilitate any cable size by soldering the center conductor to the connector’s solder-cup contact. Part Number 120A108B 120A108F 120A108G 127A577 Fig. 91 Description RG/U Cable Cable Jack, Solder Clamp 8A, 11 91 Cable Jack, Solder Clamp 58, 58A, 58B 91 Cable Jack, Solder Clamp 59, 62 91 Panel Jack, Solder Cup Any 92 Fig. 92 RoHS compliant V-Bite ® PC Edge Mount Fig. No. REQUEST QUOTE REQUEST DRAWING The V-Bite ® is an industry award winning design PCB connector with all the advantages a designer could want. It edge mounts to the board which offers the lowest profile and utilizes very little PCB real estate. It lends itself to surface mount and through-hole soldering techniques. There are versions for IR and convection reflow soldering. Because the connector locks into place both above and below the PCB it disperses rotational torque relief to the board and not the solder points. The V-Bite ® design offers the lowest VSWR ratings due to the straight through-put contact design. No right angles for reflection. Available in 50 and 75 ohm, threaded and non-threaded. Other options for PCB thickness available. Other interfaces available. See “F”, BNC Twin, TNC and N sections. Part Number 161V504E 161V504EFT 162V504E RoHS compliant Fig. No. Description N type Edge Mount Jack (TFE Insul for reflow) 98 N type Edge Mount Jack w/ Flange and Threads (TFE Insul for reflow) N Type Edge Mount Plug (TFE Insul for reflow) REQUEST QUOTE 99 100 Fig. 98 REQUEST DRAWING Fig. 99 Fig. 100 Adapters & Terminator Standard configurations of adapters are machined brass with attractive nickel plating. All contacts are gold plated brass (males) and phosphor bronze (females). Part Number Fig. No. Description 132A505 Female/Female Inline 97A 143A505 F/M/F “T” Adapter 93 145A505 F/F/F “T” Adapter 94 151A505 F/M Right Angle Adapter 95 130A5011 Male/Male Inline (Tri-Plate) 97B 132A5011 Female/Female (Tri-Plate) TC1028 50W Female RoHS compliant REQUEST QUOTE 97C 96 Fig. 95 Fig. 93 REQUEST DRAWING s Fig. 97A Fig. 97B Fig. 97C Fig. 94 Fig. 96 s N to 7/16 Adapter Kit 7/16 Adapter Kit ADPT3PA is a 8 piece kit containing 7/16 to N, N to N and 7/16 to 7/16 adapters. Made of machined brass and Tri-Plated bodies. Gold plated contacts. Kits are in zippered leather cases. Part Number ADPT3PA Description N to 7/16 Adapter Kit (TriPlate) REQUEST QUOTE Fig. No. 102 _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 s - Page 20 - Back to Index 19
132A505 价格&库存
很抱歉,暂时无法提供与“132A505”相匹配的价格&库存,您可以联系我们找货
