EHBNC2BPKG
EHBNC2BPKG
    SWITCHCRAFT
    EHBNC2BPKG
EHBNC2BPKG 数据手册
NPB 560B Sw i t c h c r a f t ® EH Series Audio/Video/Data 1. Choose any combination of EH Series connectors. The EH Series by Switchcraft® is a complete line of audio, video, and data connectors built into standard panel-mount XLR housings. Custom combinations of EH Series connectors can be quickly loaded into any of our Q-G® Series panels. Once mounted, connecting your equipment to the back of an EH Series connector is fast and easy. Most connectors are feedthru, which means standard cabling is simply plugged into the back of your gear, then plugged into the back of the EH Series connector. For those EH Series connectors that are not feedthru, solder lugs are clearly marked for simple, secure solder connections. All EH Series connectors are available individually bagged with mounting screws. 2. Choose a blank Q-G® Series panel. Q-G® Series panels come standard as 1RU (1x16), 1.5RU (1x16), or 2RU (2x16). 1RU and 1.5RU versions allow for any combination of up to 16 EH Series connectors to be loaded into the panel. The 2RU version can accommodate up to 32 EH Series connectors. Every Q-G® Series panel includes quick change designation strips for easy connector identification. 3. Populate EH Series connectors into Q-G® Series panel to create custom I/O solution for all of your audio, video, and data connections. Switchcraft's EH Series is the fastest and most versatile way to create a custom panel or wall plate perfectly suited to meet the needs of any studio, broadcast facility, or systems integrator. Customize your studio, make it easy to access your I/O's, and increase the lifespan of expensive pieces of equipment using EH Series connectors and Q-G® Series Panels from Switchcraft®. -QGPK1B440 Switchcraft www.switchcraft.com® 5555 N. Elston Avenue/Chicago, IL 60630 Phone: 773-792-2700 Fax: 773-792-2129 EH Series Switchcraft® 2 NPB 560B Audio/Video/Data E3MSCB E3FSC E4MSC E4FSC E5MSCB E5FSC E112BL EH35MMMSC EHUSBBAB EHUSBAB EHFWX2B EHFW800X2 EH6MD2 EHSVHS2B EHRCA2 EHDB9MF EHDB9FFB EHHD15MF EHHD15FFB EHFFB EHBNC2B EHLC2 EHLC2M EHSC2 EHSC2M EHST2 EHST2MB EHTL2 ECPPKG Switchcraft www.switchcraft.com® 5555 N. Elston Avenue/Chicago, IL 60630 Phone: 773-792-2700 Fax: 773-792-2129 ECP2PKG ECP4PKG ECP8PKG EH Series Switchcraft® NPB 560B 3 Audio/Video/Data Connector Options 1 EH Series Termination Housing Connector 3.5MM (1/8") Mono 3.5MM (1/8") Stereo SVHS (S-Video) PS/2 Firewire 400 (IEEE1394) Straight-Wired Firewire 400 (IEEE1394) Cross-Wired Firewire 800 (IEEE1394B) Straight-Wired Firewire 800 (IEEE1394B) Cross-Wired RCA BNC BNC (Recessed Front) BNC BNC to RCA RCA to BNC USB A to B USB B to A 9-Pin DSUB Male to Male 9-Pin DSUB Male to Female 9-Pin DSUB Female to Female 15-Pin HD DSUB Male to Male 15-Pin HD DSUB Male to Female 15-Pin HD DSUB Female to Female F to F (Coaxial) LC Fiber Optic (singlemode) LC Fiber Optic (multimode) SC Fiber Optic (singlemode) SC Fiber Optic (multimode) ST Fiber Optic (singlemode) ST Fiber Optic (multimode) TOSLINK E Series (XLR) E 2 Solder Solder Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Solder Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru Feedthru EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH EH 35MMMSC 35MMSSC SVHS2 6MD2 FW2 FWX2 FW8002 FW800X2 RCA2 BNC2 BNC2R BNCSC BNCRCA RCABNC USBAB USBBA DB9MM DB9MF DB9FF HD15MM HD15MF HD15FF FF LC2 LC2M SC2 SC2M ST2 ST2M TL2 Pins Gender Fas-Disconnect Option Termination Style 3,4,5 D=Fas-Disconnect Blank=Standard Locking ST=Straight PC Terminals RA=Right Angle PC Terminals SC=Solder Cups Blank=Conical Springs (3-Pin) M, F Connector Type 1/4" Mono Locking Jack 1/4" Stereo Locking Jack Part Number Part Number Bagged with (Nickel Finish) (Black Finish) Mounting Screws E111L E112BL E111BL E112BLB PKG PKG Finish 3 B = Black Blank = Nickel B B B B B B B B B B B B B B B B B B B B B B B (Black Only) (Black Only) (Black Only) (Black Only) B B (Black Only) Mounting Hole Options 4 Bagged with Mounting Screws PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG PKG Bagged with Mounting Screws M3=M3x0.5 Thread B=Black 440=#4-40 Thread Blank=Nickel Blank=Counter-Sunk Hole PKG Blank Hole Covers Part Number 1 Space 2 Space 4 Space 8 Space ECPPKG ECP2PKG ECP4PKG ECP8PKG *Sample EH Series Part Number: EHBNC2BPKG (BNC Feedthru, Black Housing, Bagged with 4-40 Mounting Screws) *Sample E Series Part Number: E3FSCPKG (3-Pin XLR Female, Solder Cups, Bagged with 4-40 Mounting Screws) *Male to female 9-Pin and 15-Pin DSUBS are user reversible to create female to male connectors. *All Blank Hole Covers come bagged with 4-40 mounting screws. *All EH Series Fiber Optic Connectors come with dust caps. Switchcraft www.switchcraft.com® 5555 N. Elston Avenue/Chicago, IL 60630 Phone: 773-792-2700 Fax: 773-792-2129 EH Series Switchcraft® 4 NPB 560B Audio/Video/Data Q-G® Panel Options -QGPK1B440 Empty Q-G® Rack Panels Rack Height Number of Knockouts Tapped 4-40 Holes QGPK1B QGPK1B440 QGPK2B QGPK2B440 QGPK3B QGPK3B440 1RU 1RU 1.5RU 1.5RU 2RU 2RU 1 X 16 1 x 16 1 X 16 1 X 16 2 X 16 2 X 16 NO YES NO YES NO YES -QGPK332MFB Pre-Loaded XLR Panels QGPK116FB QGPK116MB QGPK18M8FB QGPK332MFB Switchcraft www.switchcraft.com® 5555 N. Elston Avenue/Chicago, IL 60630 Phone: 773-792-2700 Fax: 773-792-2129 Height 1RU 1RU 1RU 2RU Description 16 Female 16 Male 8 Male, 8 Female 16 Female, 16 Male
EHBNC2BPKG
- 物料型号:EH系列连接器有多种型号,例如EH35MMMSC(3.5mm单声道)、EH35MMSSC(3.5mm立体声)、EHUSBAB(USB A至B)、EHBNC2B(BNC)等。 - 器件简介:EH系列连接器支持快速、简便的设备连接,大多数连接器为直通式(feedthru),允许使用标准电缆直接连接。 - 引脚分配:文档中提到了E系列(XLR)连接器的引脚分配,例如3、4、5引脚,以及公母性别(M.F)。 - 参数特性:连接器有多种终止方式,如焊接(Solder)和直通式(Feedthru)。它们也有不同的颜色选项,如黑色(B)和镍色(Blank)。 - 功能详解:EH系列支持多种类型的连接,包括3.5mm音频、S-Video、PS/2、Firewire、RCA、BNC、USB、DSUB和光纤等。 - 应用信息:EH系列适用于任何工作室、广播设施或系统集成商,以满足他们的特定需求。 - 封装信息:Q-G®系列面板有1RU、1.5RU和2RU的尺寸,可以容纳多达16或32个EH系列连接器。每个面板都包括快速更换的标识条,以便轻松识别连接器。
EHBNC2BPKG 价格&库存
很抱歉,暂时无法提供与“EHBNC2BPKG”相匹配的价格&库存,您可以联系我们找货
