SWH.00.250.CTMV
SWH.00.250.CTMV
    LEMO(雷莫)
    CONN ADAPT JACK TO JACK 50 OHM
SWH.00.250.CTMV 数据手册
SWH.00.250.CTMV www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Coupler/adapter/bridge IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model SWH*: Fixed coupler, nut fixing, watertight or vacuum-tight Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 4.61 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm Contact Retention: 18 N Contact Dia.: 0.7 mm (0.03in) Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -20°C / +100°C F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A B C D E S1 e mm. 24.5 11.0 10.2 1.5 5.5 9 M7x0.5 in. 0,96 0,43 0,40 0,06 0,22 0,35 RECOMMENDED BY LEMO Tools Crimp Tool: DPC.91.701.V LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
SWH.00.250.CTMV 价格&库存
很抱歉,暂时无法提供与“SWH.00.250.CTMV”相匹配的价格&库存,您可以联系我们找货
