FTL.00.250.NTF
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
00
Termination type
Coupler/adapter/bridge
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FTL*: T-plug with two receptacles (90 degree)
Keying
Circular (can rotate)
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
7.13 g
Performance
Configuration
00.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
4 Amps
Specifications
Contact Type: Coaxial 50 Ohm
Test voltage: 1.1 kV (rms)
Others
Endurance (Shell): 5000 mating cycles
F ret (min): 100 N
Salt Spray Corrosion: >144 hr
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
DRAWINGS
Dimensions
A
L
mm.
9
28
in.
0,35
1,10
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“FTL.00.250.NTF”相匹配的价格&库存,您可以联系我们找货
