ABA.1S.250.NTL
ABA.1S.250.NTL
    LEMO(雷莫)
    ABA.1S.250.NTL
ABA.1S.250.NTL 数据手册
ABA.1S.250.NTL www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1S Termination type Female solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.1S.250.NTAC32Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ABA*: Adapter socket LEMO - plug BNC Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) collet and crimping tube, brass (chrome plated [SAE AMS 2460]) collet nut Weight 19.04 g Performance Configuration 1S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 12 Amps Specifications Contact Type: Coaxial 50 Ohm Contact Dia.: 1.6 mm (0.06in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.23 * f/GHz Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Endurance (Shell): >1000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.1S.M12.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
ABA.1S.250.NTL 价格&库存
很抱歉,暂时无法提供与“ABA.1S.250.NTL”相匹配的价格&库存,您可以联系我们找货
