ABA.1S.275.NTL
ABA.1S.275.NTL
    LEMO(雷莫)
    ABA.1S.275.NTL
ABA.1S.275.NTL 数据手册
ABA.1S.275.NTL www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1S Termination type Female solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.1S.275.NTAC32Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ABA*: Adapter socket LEMO - plug BNC Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) collet and crimping tube, brass (chrome plated [SAE AMS 2460]) collet nut Weight 18.93 g Performance Configuration 1S.275 : 1 Coax (75 Ohm) Insulator T: PTFE Rated Current 10 Amps Specifications Contact Type: Coaxial 75 Ohm Contact Dia.: 1.3 mm (0.05in) Vtest: 2400 V (AC), 3300 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.08 * f/GHz Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Endurance (Shell): >1000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.1S.M12.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
ABA.1S.275.NTL 价格&库存
很抱歉,暂时无法提供与“ABA.1S.275.NTL”相匹配的价格&库存,您可以联系我们找货
