FTA.1S.250.CTF
FTA.1S.250.CTF
    LEMO(雷莫)
    FTA.1S.250.CTF
FTA.1S.250.CTF 数据手册
FTA.1S.250.CTF www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1S Termination type Download Request a quote IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FTA*: T-plug with two in line receptacles Keying Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 30.01 g Performance Configuration 1S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 12 Amps Specifications Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A H I L mm. 16 26.5 16.5 45 in. 0,63 1,04 0,65 1,77 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FTA.1S.250.CTF 价格&库存
很抱歉,暂时无法提供与“FTA.1S.250.CTF”相匹配的价格&库存,您可以联系我们找货
