SWH.1E.650.CTMPV
SWH.1E.650.CTMPV
    LEMO(雷莫)
    SWH.1E.650.CTMPV
SWH.1E.650.CTMPV 数据手册
SWH.1E.650.CTMPV www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 1E Termination type Female crimp IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model SWH*: Fixed coupler, nut fixing, watertight or vacuum-tight Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant PV : Watertight / Vacuum-tested unmated Weight 43.97 g Performance Configuration 1E.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Vtest: 1200 V (AC), 1690 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.17 * f/GHz Cable type: RGT 178, RGT 174,Belden 9222 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -20°C / +100°C Humidity (max): 1000 hr Pressure: 60 bars DRAWINGS Dimensions A B E L M S1 S3 e mm. 20 21.5 30.5 47 4.5 14.5 19 M16x1.0 in. 0,79 0,85 1,20 1,85 0,18 0,57 0,75 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
SWH.1E.650.CTMPV 价格&库存
很抱歉,暂时无法提供与“SWH.1E.650.CTMPV”相匹配的价格&库存,您可以联系我们找货
